possible purchace
SSI is selling a car they built(ssiauto.com): Fresh rebuild, 9.8 Euro P/C, new 930 cam, 78 911sc heads (larger ports?), new timing gears/chains/3.2 tensioners, new oil tank return and supply line, new oil return tubes, rebuilt trans, rebuilt fuel injection , SSI heat exchangers/Bozel muffler. Body/interior OK, but not great, (car repainted original color, seats recovered). New brake pads/rotors. engine has 20 miles on clock--needs to be properly run in. can provide reciepts.
Sounds like buying a fresh engine/trans ???paint(no rust)/interior.
17,500.
1. Anyone with experience with this shop?
2. Do Euro 9.8 pistons (higher compression) require mods to the ignition?
3. Are the 78 heads an advantage, or were they laying around the shop and therefore available for the rebuild?
4. Do 930 cams provide any advantage?
thanks in advance for your help.
Old 02-05-2004, 06:52 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
this is a normally asperated car? with 930 cams?
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 02-05-2004, 07:20 AM
Yes, na engine.
Old 02-05-2004, 11:32 AM
