limble's Avatar
Any European engineers?
Hey Guys n Gals,
I have a Swiss print that reads:
Hole
1.6 H7 diameter
Shaft
1.6 h8 diameter
Metric of course
My machinery handbook does not cover that combination of allowances and tolerances.
Can you provide the maximum and minimum for the above dimensions?
I’m trying to match up EU instruments with US instruments.
Thanks,
Mike
When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE.
1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation)
Old 02-05-2004, 02:00 PM
Matt_'77_2.7's Avatar
I believe you can get those allowances out of bearing books. Torrington, NSK, SKF, et al. I don't have one in front of me right now.
Sorry the torrington book I have does not go below 3 mm and does not list H8 tolerance for the shaft at all.
Google ISO 286-2
Use these net resources at your own risk.
Good luck
Matt
Old 02-05-2004, 03:16 PM
We'll I'm a long way from a European engineer but some of us "Maricans" have to deal with these "communist units" all the time.
From "Machinery's Handbook, 25th edition" ANSI B4.2-1978 R1984 based on ISO system of metric limits and fits:
1.6mm "locational clearance fit" or H7/h6
Hole H7: 1.610/1.600
Shaft h6: 1.600/1.594
Fit: .016/.000
all units are in millimeters
Cheers, Jim
Old 02-05-2004, 03:50 PM
limble's Avatar
Matt,
Thanks I'll try the link you mentioned.
Jim,
I have the same edition but couldn't find an exact match.
I'll give the EU engineers a chance to pipe in.
Thanks,
Mike
Thanks,
Mike
Old 02-05-2004, 05:09 PM
limble's Avatar
The ISO 286-2 doesn't cover shafts and holes below 3mm?
Where else should I look?
Thanks,
Mike
Old 02-06-2004, 12:34 PM
