-   -   Help! Need "rod end" for upside down RSR coil-overs! (http://forums.pelicanparts.com/porsche-911-technical-forum/147349-help-need-rod-end-upside-down-rsr-coil-overs.html)
cstreit 02-05-2004 07:06 PM
Gang,
I just received my upside down coil-over clevis kit from T.R.G. and they drop shipped the bottom "rod end" spherical bearings from Bilstein. Unfortunately Bilstein was out of the proper ones and for whatever reason just sent me the wrong size! (M12x1.25) Duh.
So.... I now have an entire suspension except for these damn rod-ends with the flange to hold the spring hat so I'm sitting on my hands untill they make more.
Does anyone have a set? I'll happily buy you a new pair when Bilstein makes them in 3-4 weeks! They have a female thread that looks to me M10x1.25
I've already asked Bilstein, TRG, Rennsport, and Patrick. Nobody ahs 'em.
Thanks!
Chris
cstreit 02-05-2004 07:23 PM
Here is a pic of what I need:
http://forums.pelicanparts.com/uploa...1076037791.jpg
Jeff Alton 02-05-2004 08:17 PM
Check with some avaiation part suppliers in your area- they will usually have all k inds of that stuff.
Jeff
cstreit 02-05-2004 08:25 PM
Calling every joint in town. Thanks for the idea.
Kevin Stewart 02-05-2004 08:31 PM
looks like a mono ball end, try laneautomotive
Jeff Alton 02-05-2004 08:35 PM
Chris, what is the diameter of the actual end, and confirm it is a female threaded 10x1.25. I will make some calls up here for you.
Jeff
cstreit 02-05-2004 09:04 PM
Jeff,
It is definitely M10x1.25 female.
Not to scale, but:
http://forums.pelicanparts.com/uploa...1076043857.jpg
Thanks for checking Jeff!
Jeff Alton 02-05-2004 09:16 PM
I will get on it tomorrow.
Jeff
Kevin Stewart 02-05-2004 09:20 PM
did you think i was kidding www.laneautomotive.com call them they sell bilsteins and are in coloma michigan, Kevin
cstreit 02-05-2004 09:26 PM
Kevin,
Sorry, Definitely not, I just missed your post somehow. They're on the morning call list now! Thanks!
Kevin Stewart 02-05-2004 10:47 PM
i cant think of a reason why they wouldnt, but you never know, Kevin
about 75 miles from chicago on 94
cstreit 02-06-2004 09:10 AM
Guys,
It turns out that Bilstein never made the M10x1.25 part. ANy part that was sold that worked was custom-made. I have my answer, not the one I wanted, but the answer nonetheless.
Matt_'77_2.7 02-06-2004 09:30 AM
But what is the solution to the problem of the missing rod end?
cstreit 02-06-2004 09:46 AM
Fabrication. I'm going to have a batch made. 3-4 weeks they should be ready.
cstreit 02-06-2004 12:26 PM
FWIW, Souk and I are fabricating a supply of these. They will be ready in several weeks. If you are interested, please contact me directly. They will be better than the originals in that you can swap the bearing out to whatever kind you what but ALSO add any pre-load to the spring you want without changing the ride height!
