-   -   looking for a better window crank (http://forums.pelicanparts.com/porsche-911-technical-forum/147404-looking-better-window-crank.html)
jmz 02-06-2004 07:21 AM
I need some new window cranks and was wondering if anyone has found something better than the stock ones. I would like something to match the rs door panels and perhaps a bit longer than stock.
suggestions?
Bill Verburg 02-06-2004 07:28 AM
If you go longer than stock you will start getting interference w/ the door speakers(if any)
TerryBPP 02-06-2004 07:28 AM
I had a problem with the knob pulling off every time I turned it. Crappy design. So I bought a set of cranks from Pepboys that matched. Better construction and longer.
Hetmann 02-06-2004 07:44 AM
The knobs are a problem. I replaced mine with lookalikes that fell apart after a while and then went to generic aftermarket, but not wild about the looks. Do you have a brand or partnumber for the Pepboys cranks? How do they look?
bob tilton 02-06-2004 08:09 AM
i bought a new reproduction set after the first set fell apart. the repro set eventually fell apart after a couple years. bought a set of used 65-6 7window cranks. i think this is a better and more durable design as i have had no problems with them in 3 years and you figure they're just about 33 years old. plus they look correct with the RS door panels.
911ctS 02-06-2004 10:02 AM
I took some off of a BMW 320i and they match the RS pannels pretty well. they are cheap and solidly built. However I have to live with the fact that i have a BMW part on my P-car.... Just have to go into a denial state of mind.;)
TerryBPP 02-06-2004 10:24 AM
Hetman, part # i don't know. But they where the in the do it yourself isle. Red package. There was a wide variety. I chose a set that was almost identical to stock.
no substitute 02-06-2004 10:37 AM
Do any of the billet VW cranks fit? I have power windows, so I'm not certain, but I assume they are splined?
Randy Webb 02-06-2004 03:27 PM
One option is the early style.
I've always wanted the ones marketed by Vilem B Haan in the 1960's-70's with holes in them -- for a ic search for my name crank and haan.
Post if you find something cool.
RoninLB 02-07-2004 09:19 PM
JC Whitney
a bunch of VW billet designs
http://www.jcwhitney.com/webapp/wcs/stores/servlet/EndecaCategoryView?catalogId=10110&Ne=1000003029&N =111+2210001811+1000003029&langId=-1&tmplframe=EndecaCategoryView&section=body&tmplho me=StoreCatalogDisplay&storeId=10101&ss=10110
jwetering 02-07-2004 10:26 PM
I went to the wrekin' yard and found a set of BMW handles that fit. They're chrome, but otherwise I don't think about them much.
