-   -   Defroster making a funny noise (http://forums.pelicanparts.com/porsche-911-technical-forum/147466-defroster-making-funny-noise.html)
donnieknoxville 02-06-2004 01:44 PM
For the past couple of years, my 1987 Carrera Cab has made an interesting noise.
When its below 50 degress or so, when I pull up on the defrost lever between the seats, a second or two will pass, then I will hear a slow, repetitive wine from an area near the passenger side footwell. It sounds like a fan that needs some oil. If I do nothing, it will continue to to emit a wha, wha, wha, wha, sound. The corrective action is usually to switch the defrost center console dial from position 1 to position 3 to get the fan moving faster. Once its run a little faster for maybe 10-30 seconds, I can switch back to position 1 or 2 without having the sound reappear.
Usually only happens during the winter months when its a little colder outside.
Any thoughts on a more permanent fix - and assuming its the fan / blower motor. Also, how do I get to it to inspect and repair?
Thanks in advance for any thoughts.
Don
