-   -   Replace caber plate bushings? (http://forums.pelicanparts.com/porsche-911-technical-forum/147467-replace-caber-plate-bushings.html)
Pat S 02-06-2004 01:46 PM
I'm installing Konis during my suspension rebuild. They came with new rubber bushings for the top camber plate, but I'm not sure if I should use them or stick with the old OEM style.
Any preference or ideas what is better?
The old ones are in good condition and very different from the replacements that came with the new shocks.
http://forums.pelicanparts.com/uploa...1076103993.jpg
Jeff Alton 02-06-2004 05:53 PM
I used my old ones. That said, i will be putting monoballs in there in a couple of weeks.
Jeff
Pat S 02-06-2004 06:00 PM
Yeah, Monoballs aren't in the budget yet.
I'd prefer to replace them but I'm not sure if that would be bad or not.
Pat
jyl 02-06-2004 07:48 PM
Are you sure those are meant to replace the rubber strut top bushing? I don't know about Konis, but I don't see how it could fit. The hole in the camber plate is bigger that any of the rubber bits in the left picture. I think those are just rubber snubbers.
Pat S 02-06-2004 07:50 PM
Nope the rubber stops are on the shocks and are much longer. And altough it doesn't look like it in the pick they are pretty close on OD, but are much thicker than the porsche ones.
Chuck Moreland 02-06-2004 08:16 PM
Pat
Most people just leave the stock rubber. I've done it both ways.
In general, I would leave the stock rubber unless it is showing deterioration. It is more substantial than the koni replacements and I would guess deforms less under load. Of coarse monoballs are the way to go if deformation is a real concern.
Wil Ferch 02-07-2004 09:39 AM
I also kept my old ones...they were in good shape.
I also guess it would maintain alignment settings by keeping the "old" hole for the upper shock shaft to pass through.
---Wil Ferch
Pat S 02-07-2004 02:42 PM
Thanks guys. I'll plan on keeping the old ones in then. I pulled them off knowing I'd loose my camber settings because I wanted to make sure all the metal on the underside was in good strong condition. Plus since I am completely rebuilding the suspension, I'd have to change settings anyway.
