dashboards instruments
Hi all
is it possible to open the tachometer, and revmeter(?) to clean under the glass ? many thanks Philippe |
Philippe, why do you need to clean under the glass? Condensation? If so, do a search on "gauge condensation".
You can use a small screwdriver or similar to pry up the "lip" of the trim ring, then remove the trim ring and the glass comes off. Afterwards, you'll be able to tell that the instrument has been opened.
I want to add the small chromed parts in the center of the instruments like the "before 73" have...;)
philippe |
| All times are GMT -8. The time now is 06:57 PM. |
