-   -   Shift Coupler replacement - done! (http://forums.pelicanparts.com/porsche-911-technical-forum/147694-shift-coupler-replacement-done.html)
Oracle 02-07-2004 10:52 PM
Hi,
I'd like to share that I was able to change the shift coupler without breaking anything :D
Anyway I just want to thank Pelican for hosting this forum and for all people who have contributed with priceless information (I must have read all threads related to shift couplers).
Here are some pictures with the old coupler (like the one Pelican has for sale) and the new (used but in good shape) which seems to be compatible but it's not as good quality as the original I should say...
I can't take out the car for a drive since roads are covered in salt, rocks and snow. But I can already tell the difference by moving the shift rod, simply less play..
I will change the other bushings: shift rod and ball cup. Today it was a good day but still too cold to do something else... (0c or 32 F)
I must say I followed Quincy's advice and that saved me a lot of time: http://forums.pelicanparts.com/showthread.php?s=&threadid=141245&highlight=shift+ coupler
Left old, right replacement:
http://forums.pelicanparts.com/uploa...1076220645.jpg
http://forums.pelicanparts.com/uploa...1076220661.jpg
http://forums.pelicanparts.com/uploa...1076220720.jpg
Left replacement, Right old, :
http://forums.pelicanparts.com/uploa...1076220680.jpg
Old one has 1mm (or more) of axial play, no wonder the shifting was so sloppy:
http://forums.pelicanparts.com/uploa...1076220700.jpg
Can't wait for the warmer time of year...
-J
GrindingGears 02-08-2004 12:20 AM
EDIT: nevermind
k9handler 02-08-2004 12:57 AM
that looks like something that could be rebuilt with ease...I never noticed what mine looked like when I removed it last summer, guess I should go and take a look.
qcwang 02-08-2004 02:50 AM
Great job!!
Hope the weather warms quickly so you can finish the other bushings.
Glad the thread on what worked for me helped you!! Wow, I contributed to reducing the struggles of mankind in the quest to survive (at least in the P-car world)! I'll go tell my wife.....she just rolls her eyes. :-)
Take care!!
Quincy
onewhippedpuppy 02-08-2004 07:15 AM
You'll be amazed when you drive it, at least I was. The coupler was a big help, but doing the other bushings made a difference as well. I did mine a few days apart to tell the difference. Just to warn you, budget some time, my shift rod bushing in the tunnel was a b!tch to get in, not nearly as easy as Wayne's book makes it sound, maybe it was just mine though.
scottb 02-08-2004 02:23 PM
Why didn't you just do the bushings?
Oracle 02-08-2004 04:42 PM
If you mean replace the coupler bushings is because I couldn't take the pin out, seems that I'll need a special high pressure machine (don't know the name) or I may need to wack it till it's out.
If you mean the shift rod and the shift cup bushing is that it was too darn cold to continue working... It took me 5 minutes to replace the coupler...
I will replace all bushings and will put back the original coupler, I bought the full bushings kit from Pelican.
Sometimes I wish I was in sunny Calif.
Bye
-J
scottb 02-08-2004 04:53 PM
If you're careful, you can tap out the center pin and replace the bushings. IYou don't need special tools. t's not a tough job, and not very expensive. Our host sells the bushings.
Schrup 02-08-2004 05:25 PM
I'll have to disagree with you Scott. I broke mine last week trying to get the pin out with a tie rod tool after trying to knock it out with a hammer & punch unsuccessfully. It doesn't take much to break the cast aluminum. I was so pissed, :mad: I refused to buy another one & instead ordered a Wevo unit for $120 more
scottb 02-08-2004 05:33 PM
The way to do it is to support the coupler by resting the bushings on a socket. Then, gently but firmly tap out the pin. It's do-able, and far less expensive than buying a new coupler if successful.
Pat S 02-08-2004 06:02 PM
I took mine to Napa, I think they charge me like $10 to press the old one out and the new ones in.
My old one was really really bad. New one felt great.
Pat
ubiquity0 02-08-2004 06:10 PM
Likewise, I just brought mine in to a friendly local mechanic down the road from me. $10 & 5 minutes later it was done.
Kemo 02-08-2004 06:54 PM
good job...i noticed a wonderful improvement after doing mine... but i did the cup ball replacement and the other thingy that the shifter shaft slides along. it cleared up the slop a little..plus i found the hex bolt thing on the front of the shifter which helped with the slop too, i think :)
Vipergrün 02-08-2004 09:27 PM
I used a block of wood with a hole drilled in it which the pin would fit through. Then I lined up the pin with the hole and knocked it out using a bolt and hammer. When the pin was out, I flipped the bolt and used the head to drive out the old bushings. Took maybe 5 minutes :)
-B
braddb_82SC 02-08-2004 10:10 PM
-B
That is exactly how I did it a few weeks ago. Worked well.
It seems we share the same mind as well as the same first and last name and almost the same car. Same state too.
-Brad Brown
Vipergrün 02-09-2004 07:54 PM
Crap, that IS eerie...seeing someone else with my name.. My wife frequently calls me *********, maybe I'll just go by that here too :)
Randy Webb 02-09-2004 09:25 PM
maybe she is referring to the other guy -- both of you can use that....
