Where can I get a bung hole for a euro premuffler?
Bought a premuffler and I need to add the bung hole for the o2 sensor. Can you pick those up locally you think or do I need to order it from a specific place?
Thanks, |
Friend of Warren
auto parts store. same size as a spark plug
Kurt V No more Porsches, but a revolving number of motorcycles. |
Hilbilly Deluxe
Drill a hole and weld on an apropriate sized nut.
Any competent muffler shop should be able to do this. Tom |
I'll weld it on myself, I was just wondering if there was a special part I needed. I will just goto the autoparts store and get a antifouler, mod it and weld it on. Should have searched before I asked I know.
Ayyyyy am cornholio! ...do you need teepee for your bunghole?
78 911 SC "Scratchy" 2004 Mini Cooper S "Pele" (gone but not forgotten) 1979 classic mini clubman-"Coolio" |
Talk to Jerry Woods ( yes..Bruce Anderson's friend and confidante)...
about $10 or so....weld it in yourself or have it done... --Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Is there a particular depth that the sensor should installed to? I seem to recall this fact.....but perhaps more critical with a broad spectrum sensor.
Warren & Ron, may you rest in Peace. |
I think the 18 mm x 1.5mm bung hole size is correct, but I believe ( somebody help me here )...it's a taper..like the trans fill and drain plug hole or an NPT thread.
Thread it down till it stops, then... --Wil Ferch
Somewhere in the Midwest
I am almost sure that it is an 18mm fin1 thread bung you'll need..common for all O2 sensors. Any place that sells O2 sensors should be able to sell you on for less than 5 bucks...
I recall seeing it in the Jegs and Summit caltalog as I was thumbing through them last night... If Jegs has it, Pepboys or Napa or AutoZone should have 'em. |
Wil..you might be right about the taper threads, like NPT, and the 18MMX1.5 is right too. I recall seeing a crust type washer on the O2 sensor that I cut up to make a plug for my pre-muffler....that makes me think it's not a taper...hmmmm
Friend of Warren
Nope, no taper, uses a washer.
We sell an O2 sensor bung-holio, pt# PEL-SW85-21688. Just give me a call at ext 248
Thank you! John johnechi@hotmail.com Last edited by chibone_914; 01-29-2004 at 01:59 PM.. |
Ok... but it *IS* 18 x 1.5 mm ........thanks for the other corrections....
---Wil Ferch
Too much Beavis and Butthead....
Harlan Chinn Pacific Northwest Region 1998 Carrera S ArcticSilverMetallic 1982 911SC PazificBlauMetallic |
AS I remember the nut that holds down the steering wheel of a 914 has the right threads and just the right thickness. Just weld it on to the premufler or testpipe. (drill the hole first.
I had been shaking from the effort to not go the Beavis and Butthead route on this one. I'm glad someone did. I can relax now.
Phhheeeeew!
ee hehe hehe i need tp for my bung hole
Senior Member
Kerry, you already have a bunghole, don't you?
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Smart quod bastardus
Go down to Ramchargers and ask them for some tee pee for your bunghole. He,he,he.
They will have them there for a couple of bucks.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
