GrindingGears's Avatar
Break in period for rotors and pads?
Is there one?
How long is it?
'83 SC, OEM rotors & pads.
83 SC (gone) // 72 T (gone)
Old 02-10-2004, 06:44 PM
The break-in period is about a half hour long, if you do it right. Everybody has a different recipe, but basically it's something like half a dozen moderate but firm slow-downs from 60 to 20, with cool-down periods between stops, then a fairly hard stop from 80 to 0, run for a mile or so to let the brakes cool, then a harder one from 90 to 0, cool down, real hard from 110 to 0, cool down, then one final to-the-point-of-lockup stop from 135 or so, then don't touch the brakes or the parking brake, let the car drift to a stop and sit there for 15 minutes without touching a thing.
Then your brakes are "broken in."
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 02-10-2004, 06:59 PM
wow, i'm gonna have to take notes on that response, thanks.
edit:
now the question is where do i do this... : )
i was thinking on an 110 off ramp near my house, later tonight. i could circle the same stretch of freeway for 30 mins so using the off ramps as my hard brake zones.
any better ideas?
Old 02-10-2004, 07:19 PM
Zeke's Avatar
Search this under 'Bill Verburg.' I don't recommend or think it's necessary to go 135 to break in your rotors/pads. But Steve has got the essence of it. The cool down and no pressure on hot rotors is the important part. Different pads need different break in procedure. I broke my PU pads at street speeds. I broke my 911 pads in somewhat like he said, but w/o the excessive speed. I broke my race car pads in any way I could because you can't pull that go fast and slow down routine very well at the track with other cars on the track.
Old 02-10-2004, 07:22 PM
"I broke my 911 pads in somewhat like he said, but w/o the excessive speed."
are you implying a bunch of the 60-20 stops? how did you do it?
EDIT:
zeke, i searched and found this article.
http://www.zeckhausen.com/bedding_in_brakes.htm
thanks
Old 02-10-2004, 07:27 PM
