Send a message via AIM to tkrefeld
Changing Fuel filter
Can someone walk me through this for my 73 CIS? I Want to do it.
Old 02-10-2004, 09:37 AM
HarryD's Avatar
Hi,
you are in for some fun. The original fuel filter is NLA so you will need to fabricate something.
Here's my story:
http://members.rennlist.com/harryd/1973FuelFilter.htm
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 02-10-2004, 12:01 PM
Thats why I love this forum. Who else would document that for the pure sake of helping others(or remembering themselves)
Thanks!
Old 02-11-2004, 06:20 AM
Senior Member
Superman's Avatar
Awesome. One important trick in replacing those can-type CIS filters is to use two wrenches on each fitting, and configure the wrenches so that the force you want applied, is applied by squeezing them together. One will hold the filter, while the other turns the fitting. Again, they should be configured in a "V" shape so that you can just squeeze with one hand to pop it loose.
Mocha 1978 911SC. "Coco"
Old 02-11-2004, 06:30 AM
when replacing the filter in my 76 I went to the local auto parts, and started to check the book for all cis cars I can think of. I compared ny filter to those. I ended up with a filter out of a saab or volvo I cant remember, but it fit perfect. It had the same fittings on the ends, the only difference was it was a little longer than the old one.
Old 02-11-2004, 06:37 AM
HarryD's Avatar
Aw Schucks...
Thanks Supe. You are right about the fittings and, as best I recollect, the folks at Bosch were kind enough to make the nuts different sizes so you only need one set of wrenches to do the job.
Harry
2020 MB E350 4Matic
Old 02-11-2004, 05:45 PM
HarryD's Avatar
I tried that first. I when through the Wix catalog at one place and the Baldwin Catalog at another. No dice!
Harry
2020 MB E350 4Matic
Old 02-11-2004, 05:46 PM
HarryD's Avatar
Thanks!
You are welcome. Glad to help. I see it as paying back some of my Karmic debt.
Harry
2020 MB E350 4Matic
Old 02-11-2004, 05:48 PM
