-   -   Front end “clunking” sound (http://forums.pelicanparts.com/porsche-911-technical-forum/148114-front-end-clunking-sound.html)
Silveresrty911S 02-11-2004 05:36 PM
Wayne,
You sure it's not "Quacking" ;)
Rick
David 02-11-2004 05:56 PM
I had a similar clunk on my 79 930. I found it to be an improperly installed retaining (roll) pin on my Bilstein struts.
curlesw 02-11-2004 07:46 PM
It's not Quacking yet...but will be soon, with a couple of extra "goodies"as well :D
Thanks Shifter, I'll check that as well.
V/r
Wayne C.
83 SC
Coming soon…pictures of the Ruby Red Duck!
Mike Kast 02-11-2004 07:46 PM
There isn't much to it wayne, You have your a arms, shocks, sway bar and tie rods
The torsion bar is inside the a arm tube, the ball joint is where the shock and the a arm come together and the tie rod fastens to the steering rack
i think the motor is a little more complicated
