Squeaky Brakes After Boxster Upgrade...
Hello All,
My new brakes make a HORRIBLE screeching sound. I just did a Boxster Monobloc conversion on my SWB and I believe the Boxster caliper have sequentially sized pistons to eliminate squeaks. I've got new Zimmerman X-drilled rotors and Mintex C-Tech pads. How do I solve the sound problem. It's embarressing to say the least... To have everyone at the stoplights stare at you as you brake.... Thanks and have a good week ahead! Sprint. |
Thats mintex for ya.....go drive the crap out of the car and bed some different pads in. I have run these brakes on my car and have squel regardless of temp from 20 degrees to over 100 on a hot summer day. Great brakes...you're gonna love em.
Have a good week ahead, Dude! Sprint. |
Me like track days
Go to your local auto parts store - buy some stick on anti-squeal shims.
You can combine /cut down the ones you'll buy - they work GREAT! Craig @RS
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Sprint. |
Me like track days
I put them on the inner/outer portions of the 911s' brakes;
four pieces in all. They are quite inexpensive and work great on my Pagid Oranges! When you change pads, you will need to buy new ones - the stickum is toast and the shims get brittle. Craig RS Here is a pic off my website of them installed: |
Sprint. |
PRO Motorsports
Did you check to make sure the metal brake shield isn't rubbing against the rotor?
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Not to go off topic, but are dust shields important? How many run them and how many go without them? More wind to cool the rotors? Sprint. |
