Fuch 6/7 offset
Can someone tell me the offset for 16" fuchs. I have the 6" front and 7" rears and I'm looking at fims with an offset of 52 mm so I want to know what size spacers I would need to factor into the cost of the new rims.
Thanks for your help. The fuchs are factory standard on a 82 SC. Michael |
16x6 Fuchs offset is +36mm
911/930 & 951 (looks like a 16x6 w/countersunk lug holes) 16x7 Fuchs offset is +23.3mm |
Thank you very much.
So then, for 52mm offsets, I would need the following minimum spacers agreed?
Front: 52 - 36 = 16 mm =>> .63" Back: 52 - 23.3 = 28.7 mm =>> 1.14" |
If the +52mm wheel is also 6" wide yes, it needs a 16mm spacer but if the +52mm wheel is 7" wide then the correct o/s is ~+24mm which means it wants around a 28mm spacer. |
You are correct in your assumption that the front is 7". How did you come about your formula to know how much more offset to add?
If you understand what o/s is everything else is simple arithmetic
http://www.pelicanparts.com/MotorCit...AQ-diagram.gif |
Thank you so much. Excellent diagram.
Since my rear tire to be is 8" (currently 7"), then I would assume that I need a ~37 mm spacer? Don't have my calculator handy but that seems like a pretty big spacer for the rear. It's a street application but am I pushing the bounds.
Assuming the 8" wheel has the same +52mm o/s then you need a 41.4mm spacer in the back becaise correct o/s there for an 8 is 10.6mm. Yes, that is quite large:(
| All times are GMT -8. The time now is 09:24 AM. |
