| emcon5 |
02-16-2004 02:03 PM |
Originally posted by rdane
You guys seem to be talking the parts alone. I am talking a turn key conversion to twin plugs.
I was under the impression that you were doing your own work. Yes, I am talking parts alone, with the exception of:
-Having Steve convert the distributor
-Machine work for the second plug (heads, valve covers, chain box)
-swapping the gear on the crank.
This is the only work that isn't DIY friendly, above and beyond what would be done in the course of a rebuild.
David, my $1700 figure was everything I spent to convert my SC engine to twin plug. If you take your car to a shop and say "twin plug this" it will be MUCH more expensive. I removed the engine, I tore it down, I took my heads to the machine shop, I did the wiring, I mounted the CDI box, I modified the engine tin for the lower plug wires, etc.
Paying someone else to do all that labor, would raise the price significantly. All that for $2800 sounds like a hell of a deal
I am glad my labor is free.
Tom
