Dumb . . . Really dumb question
I'm just about finished with the tranny and started to put the end cap on when I realized I didn't take a picture of where the ground strap goes . . . . . I know its on the passenger side, but which stud does it go on????:confused:
Help would be much appreciated at this point since I am almost finished. TIA |
Can't quite remember, but it's either that one or the next one clockwise (as depicted). It doesn't really matter since either should be close enough for the strap to attach at the other end.
look ok to me...can't recall which mine is on.
Thanks guys . . . she's all sealed up and filled with fresh tranny fluid.
an extra long ground strap to the starter bolt won't hurt..
how dumb does that make me if I can't answer a really, really dumb question? ok-don't answer...
You have it on the correct bolt per the factory shop manual. Jim
i alway heard it was wise to change that strap to a new one whenever possible. what do you think? when i am there i am also going to add and extra one.
cliff |
I like electrical overkill, and back ups. I also use Neverseize Loctite Graphite-50 for spark plugs. If you read the copper can you can't find spark plugs for suggested use.. you can find that on the Graphite-50 can info.. computer gizmo wiring is another story. |
| All times are GMT -8. The time now is 07:18 PM. |
