Now why would you make the hole in the wheel so small that the socket will only barely fit. So small in fact that an impact socket will NOT fit. Now I gotta go out get a regular 27mm socket, which I'm sure I'll be using on a daily basis. Grrrr..
Stef |
Stef,
It is a conspiracy by the 27mm socket people.
2001 Turbo |
For the wheel nut, I think you'll find that a 1 1/16" is good enough. You might have that in your 1/2' drive non impact set.
Good idea! Found one - still didn't fit. Employed angle grinder for custom socket modification. 930S wheel is on!
![]() Stef |
