Britain Smith's Avatar
Steel vs. Aluminum Trailing Arms
Just in case anyone was wonder, I thought I would show the differences between the steel trailing arms from '69 and the aluminum ones from '87. The geometry between the two appears to be very similar with exception to the angle on the shock mount.
'69 912 w/ 2.3L Type-4 Turbo Engine
'74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans.
'80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks
-- www.britainracing.com --
Old 02-13-2004, 10:33 AM
What is the weight difference?
'69 911E 2.7MFI ;996TT;987.2 CaymanS
'71 Volvo P1800E wife's; AMG SLK wife's
'71 Volvo race car
944S; 986S ; 734WHP drift car (son's)
Old 02-13-2004, 10:57 AM
I will weight them out later tonight...I have to figure out how to get the nut off the spindle to take of the axels.
The biggest difference is the 3.5" bolt spacing for the calipers. I have carrera rotors and capilers now.
-Britain
Old 02-13-2004, 11:16 AM
304065's Avatar
Calzia tells us that the steel arm weighs 16# with the inner stub axle and no outer stub axle. So it weighs more than 16# complete.
He says the Aluminum arm with bearing and no stub axles weighs 12#.
The 87 has a six bolt inner axle whereas the 74 and earlier have a four bolt.
When I do this mod myself (allowed as the geometry doesn't change) I'll measure the actual weight savings. I heard it was 5# a side.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 02-13-2004, 11:17 AM
Randy Webb's Avatar
The actual wt. savings is 6.0 lbs. - both arms, incl. swaping the hubs too, and using a NBS traceable scale.
You can figure 1/2 of that is sprung savings.
Old 02-13-2004, 11:33 AM
Published reports indicate the alu version is also stiffer....
--Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-13-2004, 11:50 AM
Randy Webb's Avatar
Will, I've heard that before but never seen it in writing. Do you know where that is?
Old 02-13-2004, 12:15 PM
Senior Member
Leland Pate's Avatar
Let's try to get Eric to drill holes in his banana arms to reduce weight!
Chief Architect and Mastermind,
SCWDP
Old 02-13-2004, 12:25 PM
Bill Verburg's Avatar
Unless the late one is off a 930 or t-look the brake bolt pattern is 3" o/c. Only the short 930 arms use 3.5" and they are in the trailing rather than leading position as they are on 911s
Bill Verburg
Old 02-13-2004, 12:29 PM
I believe it may have been in BA's book...maybe even Frere's book, where the add'l stiffness is mentioned.
Bill V... good catch...the 3.5 spacing / 930 issue. Which forces me to ask..aren't the 911 / 930 banana arms different as to geometry...or is it all in the body pivot points?
---Wil Ferch
Wil Ferch
Old 02-13-2004, 01:08 PM
Both, the 930 arms are shorter and the pivots are placed differently.
Bill Verburg
Old 02-13-2004, 01:10 PM
Ludwigsen also mentions the alloy trailing arms are stiffer.
Old 02-13-2004, 01:15 PM
304065's Avatar
Britain, what is your plan for the swaybar mounting hardware?
'81 R65
Old 02-13-2004, 01:19 PM
Team California
speeder's Avatar
The only good reason for changing them is the stiffness issue; the weight savings is negligible on a street car.
Denis
Old 02-14-2004, 12:19 AM
TOO RUF's Avatar
What year did they change from steel to aluminum? My 74 has aluminum. I'm not sure if they are stock though.
Old 02-14-2004, 08:05 AM
When does the increased stiffness become significant? I assume it only affects camber change...
With waht setup do they deflect sinificantly on street tires, on 225/15 hoosier radials, or not until huge slicks are installed?
Anyone have any data?
'71 Volvo race car
Old 02-14-2004, 08:31 AM
poorsha's Avatar
TOO RUF:
74 was the first year for these.
78 911SC sunroof Coupe (SOLD)
97 328i Convertible
Old 02-14-2004, 08:46 AM
Randy Webb's Avatar
I think it was about '74 - I got mine off a '77, and have not checked my '75 to see what it has.
"the weight savings is negligible on a street car"
- OK, I have to ask the basis for this assertion. Have you done any calculations? any subjective test comparisons?
The wt. loss is in the rear so F/R dist. is affected. It is low on the car so body lean effects are nil. But 1/2 can be regarded as unsprung, so wheel/road effects are affected. I see two potentially useful things here. But my only claim is "potentially useful."
Old 02-14-2004, 11:24 AM
poorsha's Avatar
Seems to me when I replaced mine, I noticed a fair ammount of weight difference. But it was a lng time ago.
The aluminum ones clean up real pretty.
97 328i Convertible
Old 02-14-2004, 12:30 PM
I measured a 5.5 lb weight difference between alloy and steel. It's the same effect as shaving a few pounds from each Fuchs wheel; only a portion of the lighter control arm would be considered unsprung weight.
The alloy arm above is from a '74-'77 that uses a ball attachment for the sway bar drop link.
Sherwood
http://members.rennlist.org/911pcars
Old 02-14-2004, 01:32 PM
