Rear wheel bearing tool
I have not had any luck on the 'used parts' board.
I am looking to buy, rent, or borrow the rear wheel bearing removal and reinstall tool to change out the rear wheel bearing on my '87. I need to change the bearing with the hub still on the car.
Any takers?
Randy
'87 911 Targa
'17 Macan GTS
Old 03-08-2004, 11:25 AM
chrisp's Avatar
Some places rent porsche tools.
'83 SC
Old 03-08-2004, 11:42 AM
dfw911's Avatar
I was able to change mine without the tool. I just heated the a-arm up a bit and used a punch to carefully tap the old bearing out and then pressed the new bearing in with a threaded rod and some large washers. I also heated the A-arm and froze the bearings before pressing in. I won't say it was an easy job overall but the removal and replacement of the bearings themselves wasn't too bad. Here is another link: Wheel bearings
Bart
'72 targa 2.7
Old 03-08-2004, 11:46 AM
