Bags's Avatar
Dust cap help
I hate to be such a moron but does anyone have any tricks on getting the dut cap off the fron hubs so I can finish changing rotors etc.???? I've hit, tapped, wrenched. I can't twist cause the rotor twists. THANK YOU
Mike
Old 02-14-2004, 03:46 PM
You'll never twist it off. It needs to come straight out from the hub, and the standard way of doing it is alternate pry-pry-pry-pry maneuvers with a big screwdriver or a cold chisel, using the hub as a fulcrum to put outward pressure on the cap. It requires going around and around the thing, getting it out a micrometer at a time here and there and everywhere, until finally it comes loose. You can't bang it and hope to make it come off with one mighty blow, you can't twist it, it's a cumulative process. One thing that might help you get a grip on it is to clamp a hoseclamp around it really tight, to give your screwdriver some extra purchase. If all else fails, try a good penetrant and heat on the hub, to make it expand away from the cap.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 02-14-2004, 03:55 PM
Bags's Avatar
Thanks Stephan I'm on my way back out to the garage!!!!
Mike
Old 02-14-2004, 04:19 PM
Noel's Avatar
My preferred method is to use the claw side of a hammer and pry a section using a lug as the fulcrum point. Then rotate the rotor about a half turn and do it again. The cap usually moves about 1mm per pry motion. Do this and be patient and it WILL come off.
Noel
Old 02-14-2004, 04:22 PM
I clamp vice grips onto the cover and wiggle as I pull outward. Works like a charm.
Chris
'75 911s 3.2 - Ice Green Metallic
‘87 951, '05 987 S
'21 Jeep Gladiator
‘18 Tesla ModelX 100D, ‘20 Model 3
Old 02-14-2004, 04:25 PM
A 2" *muffler clamp* is the perfect size to fit the cirumferential groove..use this as a fulcrum point and work it around slowly ...
930/Turbo (nuclear) dust caps have their own problems...
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-14-2004, 04:26 PM
I couldn't get mine off either so I heated it up the hub with an oxy-acetylene torch and it came right off.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 02-14-2004, 06:15 PM
Decolliber's Avatar
This has come up before. Do a search and you find a lot of creative solutions. The one that worked for me was a pair of large channel lock pliers. Grip the cap at a 90 degree angle and rock the pliers up and down.
John C
1988 911 Carrera coupe
2002 BMW 530
Old 02-14-2004, 07:13 PM
jbripps's Avatar
Took us over an hour and a half our first time. I think the muffler clamp idea is the best. I found this out AFTER my first removal, but will use it in the future.
regards,
Jon
'85 Targa (recently acquired by Coollx)
'02 Carrera 4S (holy moly...I'm in heaven....in the snow too)
'06 BMW 325i (gone and forgotten)
'03 Honda Odyssey (more dings every day....thanks wifey)
Old 02-14-2004, 07:44 PM
MBruns for President
JeremyD's Avatar
I tried all three and the one that worked THE BEST for me was two hammers - put one end of the claw under the ridge of the dust cap, hit the hammer on the head with hammer #2 - worked like a charm for me - and much easier than option a or option b
Old 02-14-2004, 07:55 PM
Bags's Avatar
Thumbs down
I went back out and tried the patient tapping. Also had a muffler clamp and channel locks. No luck so far. I placed penetrating spray to sit overnight and will try heating it tomottow. Will butane get it hot enough?
Mike
Old 02-14-2004, 08:40 PM
I don't know if butane is going to get you enough heat, you need to heat the hub to get it to expand enough for some clearance. You will also have to regrease you bearings and replace the seals.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 02-15-2004, 07:25 AM
Somatic Negative Optimist
Gunter's Avatar
Bags: Go with the above: Use large channel locks and rock up and down. Or muffler clamp. Spraying penetrating oil on it is o.k. I would not use heat.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 02-15-2004, 09:52 AM
