-   -   SC headlights - how to make them brighter? (http://forums.pelicanparts.com/porsche-911-technical-forum/149056-sc-headlights-how-make-them-brighter.html)
ben@benlovejoy. 02-16-2004 03:40 PM
Preferably without replacing the headlights ...
Is it possible to fit a brighter bulb? The beam is pathetic!
Ben
HarryD 02-16-2004 03:42 PM
Do have H-4's or US Sealed Beams?
With H-4's, you can get a new bulb. If you have US Sealed beams, a lower cost alternative to the Euro H-4's is the Hella H-4's that fit in the US lamp bucket. If you increase wattage, be sure to get the hedlamp relays to avoid melting you Porsche switches.
Bob's Flat-Six 02-16-2004 03:51 PM
Yep, what Harry said.
Rouxzy 02-16-2004 04:31 PM
I'm in the process of changing mine over now. I installed the Euro H-4's last winter and now I'm replacing the bulbs with 100/130 bulbs. But before one does the new double relays along with new bulb sockets and 10 guage wiring is going in. What I'm trying to say is as you go to more powerful lighting the rest of the setup needs to be updated also. Check with Daniel Stern Lighting, he has a Website that will educate you in the matter. He's at www.danielsternlighting.com
Tom
ben@benlovejoy. 02-16-2004 04:57 PM
Whatever was standard on the ROW car, so I guess H-4s?
Thanks for the link - seems the relays aren't expensive and the heavier wiring should be no problem, I have a good sparky.
Ben
Aussie 02-17-2004 02:30 AM
You could replace the globes with xenon globes or blue vision bulbs, I did it with the H1's in my old 911 T and it made a big difference, no need for any rewiring either just a simple globe replacement.
I know they make them for H4's too.
The ones I got were called Philips Vision Plus
Philips
AirCooledExcellence 02-17-2004 02:35 AM
Ben,
See here:
http://members.rennlist.com/msucro1/relaykit.htm
This guy sells relay kits designed especially for 911's includes all instructions. Just got mine yesterday!
Cheers,
Tim.
Bill Verburg 02-17-2004 03:13 AM
You can install brighter, higher wattt bulbs, but be sure to use relays in conjunction w/ them. I have the same lights and use 60/100 bulbs. In addition the reflector sometimes gets dull/dirty w/ age. They can be disassembled for cleaning.
I used to think that the 60/100s were the best posssible lights but they come in a distant second to the Zenons in my Audi. I don't know if the Zenon types can be retrofitted to a 911:confused:
ben@benlovejoy. 02-17-2004 03:30 AM
Thanks, all. Tim, that kit looks perfect - 130w bulbs should do the trick!
Bill, I'm sure a Xenon conversion is possible, but you'd be talking many hundreds of dollars!
Ben
AirCooledExcellence 02-17-2004 03:35 AM
Yeah, it's well made, and only costs $25, including shipping to the UK!
I looked up the price of the relays/sockets/wiring on maplin.co.uk and it came to well over £20.
Cheers,
Tim.
Jadams1 02-17-2004 06:46 AM
Rouxzy
Good website, very informative.
trj911 02-17-2004 08:20 AM
I just upgraded mine with H4s and new relays over the weekend. Easily done and there is even a tech article on this site which you can follow.
