Senior Member
Doug Zielke's Avatar
JW's tip really does work!
It helped get my friend's 3.0 through our (strict as CA) smog test.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 02-17-2004, 08:07 AM
RETIRED
Joe Bob's Avatar
John.....this on a very good running 3.6. What "other" problems would there be besides the failing cats?
2012 ML350 3.0 Turbo Diesel
Old 02-17-2004, 08:11 AM
Jeff Alton's Avatar
Some folks up here put a quart of methyl hydrate in with the gas. Apparently helps.
Jeff
www.turn3autosport.com
Old 02-17-2004, 10:16 AM
Fuchs w h o r e
I don't think disconnecting an injector will get you anywhere. Doing so will cause the O2 % in the exhaust to rise substantially. Their testing machines measure O2, and when its too high it dilutes the reading, so they assume the problem is a massive exhaust leak. Their computer will then assign a multiplication factor to your HC/CO readings, bringing them back up to where they are now.
The best way to beat the test when you are that close is to knock back the idle advance 2-3º.
Old 02-17-2004, 11:04 AM
RETIRED
Joe Bob's Avatar
I broke down and bought a used smog tester. They made most of the old machines obsolete when OBD came out....you would think some company would have made some type of interface to make them compliant.
Anyways...200 bucks and a I got a machine that will do all the gases and I can play with it and validate all the intereting information I have here on MY time, not a wrench's that gets 90+ an hour.....
Old 02-17-2004, 11:39 AM
Mark Wilson
Guest
Posts: n/a
Mike, if you test with the RXP stuff, I'd love to know the results. There is a automotive talk show guy in Dallas that really believes in it's use for emissions reduction. I know he gets paid to advertise, but he seems credible.
Old 02-17-2004, 12:24 PM
don't knock the delete injector trick until you've tried it. (this is for non OBDll engines). it does work.
206 637 4071
Old 02-17-2004, 01:02 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Originally posted by mikez
The bank with the 02 sensor is higher on the HC....BUT....is not the control of mixtures via the DME for ALL cylinders?
Yes, but the input for that control comes only from one bank since your exhaust setup does not have a mixing chamber.
And you are lucky. The clean bank will become much cleaner by disconnecting one injector. One barrel will just pump air and dilute the exhaust gasses like John said. Tou can pass while the oxygen sensor on the other bank does not notice the hoax.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 02-17-2004, 01:13 PM
RETIRED
Joe Bob's Avatar
Originally posted by Mark Wilson
It's called RXP. Try THIS site.
Only place that carries it is out of it....will try it when it gets back in stock.
Old 02-18-2004, 07:55 AM
Unregistered
sammyg2's Avatar
just think how clean it would run if you disconnected all the injectors! bet you could qualify for the carpool lane
Old 02-18-2004, 07:59 AM
RETIRED
Joe Bob's Avatar
Gee thanks buddy......aren't you supposed to be working?
Went to talk to the muff guy yesterday....the cats have a 25K warranty....but only after I take them off and send them back and then they examine them.....
Took a pyrometer to them when they were hot.....the inlet and exit temps are supposed to be ~100F different.....they ain't.....
Oh well, I get to play with my new exhaust analyzer this weekend and play with cocktailed fuels....
Old 02-18-2004, 08:03 AM
mikez, where did you get the exhaust analyzer? What's the model?
Old 02-18-2004, 08:35 AM
RETIRED
Joe Bob's Avatar
The analyzer is a Behr and as soon as I get it will post pics and the model #....
Old 02-18-2004, 08:54 AM
Unregistered
sammyg2's Avatar
I sold an atlas bear gas analyzer about 18 months ago for $175, didn't have a use for it at the time and it was taking up space.
A local gas station went self serve/car wash and I picked up a bunch of stuff for almost nothing. I think I paid $200 for the stuff and ended up selling it all for $2500
Old 02-18-2004, 09:23 AM
