-   -   Spark plugs...should I clean or get new ones? (http://forums.pelicanparts.com/porsche-911-technical-forum/149417-spark-plugs-should-i-clean-get-new-ones.html)
H.G.P. 02-18-2004 03:37 PM
I'm about 120 miles round trip to my main source of parts (except when ordering). So I checked the plugs today, they had carb, cleaned them. Should I stick with these, or order new ones? Thanks.
rfuerst911sc 02-18-2004 03:51 PM
I think as a general rule you should replace the plugs in the 10-15,000 mile range,if you want to take them out before that and clean them thats fine but for about $2.00 a piece for standard copper plugs I would replace.
Por_sha911 02-18-2004 03:53 PM
How long does it take to clean 6 plugs? Is your time worth more than $12?
no substitute 02-18-2004 04:04 PM
Rebuild them.
DG624 02-18-2004 04:07 PM
Joe, I was thinking about a Wong CHip. I have a '86 Carrera with no engine mods. I am also interested in your results with the B&B muffler with the SSI exhaust. How is the sound, is it too noisy?
fireant911 02-18-2004 04:21 PM
DG624,
I know that this is off of the original thread and I hope that we do not get scolded... In reference to your question about the B&B exhaust and the loudness I do have an opinion. When I purchased my car the previous owner had installed B&B stainless steel heat exchangers and muffler. At the current moment I am removing this entire exhaust system because it is way too loud for my taste and the drone at cruising speeds is not audibly pleasing to me. I am going to be installing the factory style exhaust - hopefully it will be completed this weekend.
http://www.pelicanparts.com/support/.../pimpflash.gif
DG624 02-18-2004 04:57 PM
Daryl,
Thank you for the information. I guess it is best to see how the system works before I buy.
I am usually off the subject. DIVERGENT THINKING.
scottb 02-18-2004 04:59 PM
I've NEVER re-used plugs on any of my cars. For a couple of bucks apiece, it's just not worth the hassle. On the helicopter, however, they're about $30 each (and there are 12 of them) :eek: so as long as they're within specs, they get cleaned regularly and reused.
Darkmoon 02-18-2004 06:48 PM
Is the BB exhaust for sale?
kepperly 02-19-2004 04:47 AM
Auto Zone has the copper bosche plugs for $00 .99 ea. New
please with no anti seize. I pitched my B&B also. Really load with
a cabriolet. Replaced with a Burch cat bypass and Burch single
in/out and Steve Wong chip.Differant Car!! much less noise
and smoother too!
Keith Epperly 87 slant nose turbo look carrrera cabriolet
911SCfanatic 02-19-2004 06:27 AM
Maintenance interval indicates every 24 months regardless of mileage, perhaps because they are basically imersed in oil when the car is parked.
H.G.P. 02-20-2004 12:58 PM
Checked today, AutoZone, NAPA, nor Advanced have my plugs...Bosch W5 DC.
Wayne 962 02-20-2004 01:23 PM
You must get the proper heat range for your car - simply getting a plug that will fit in the hole is not enough...
-Wayne
vash 02-20-2004 01:30 PM
i ordered two of those tuneup kits from pelican. i now have extras parts as things come up. with you living so far from everything, maybe you should get three.
