dfw911's Avatar
High side of fuse box?
First off, let me hold up my hand and admit that I am an electrical idiot. I'm installing Surco's headlight relay and the instructions say to connect a couple of wires to the "high side" of the fuse panel. On my 72, the fuse panel is vertical, so there is no "high side" like there is on an SC. Any tips on which side to connect to?
Bart
'72 targa 2.7
Old 03-07-2004, 07:06 AM
Early_S_Man's Avatar
Porsche Crest
Bart,
The high side refers to unfused/direct battery bus. You can use the small M5 accessory screw on the battery positive connector ... if your car still has the OEM battery connector on its' battery.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 03-07-2004, 07:20 AM
dfw911's Avatar
Warren, Thanks for the quick reply. That was exactly what I needed
Bart
'72 targa 2.7
Old 03-07-2004, 07:23 AM
Par911's Avatar
I have the Sucro relays also, please post pics of your installation when it's done. I would like to see where you mounted them. Thanks.
Old 03-07-2004, 09:33 AM
Somatic Negative Optimist
Gunter's Avatar
Search under: "Headlight relays" and you will be rewarded.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 03-07-2004, 11:45 AM
