Squeaky Brakes After Boxster Upgrade...
Hello All,
My new brakes make a HORRIBLE screeching sound. I just did a Boxster Monobloc conversion on my SWB and I believe the Boxster caliper have sequentially sized pistons to eliminate squeaks. I've got new Zimmerman X-drilled rotors and Mintex C-Tech pads.
How do I solve the sound problem. It's embarressing to say the least... To have everyone at the stoplights stare at you as you brake....
Thanks and have a good week ahead!
Sprint.
Old 02-23-2004, 09:24 AM
Thats mintex for ya.....go drive the crap out of the car and bed some different pads in. I have run these brakes on my car and have squel regardless of temp from 20 degrees to over 100 on a hot summer day. Great brakes...you're gonna love em.
Old 02-23-2004, 09:50 AM
Err... But the squeal comes only from the right hand side? Ok, I'll bed then in more and report back.
Have a good week ahead, Dude!
Sprint.
Old 02-23-2004, 03:51 PM
Me like track days
Craig 930 RS's Avatar
Go to your local auto parts store - buy some stick on anti-squeal shims.
You can combine /cut down the ones you'll buy - they work GREAT!
Craig
@RS
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 02-24-2004, 10:46 AM
Craig
@RS
And should I also add the anti-squeal shims on the side that doesn't squeal? The brakes gotta be equal, right?
Sprint.
Old 02-24-2004, 10:51 AM
Me like track days
I put them on the inner/outer portions of the 911s' brakes;
four pieces in all. They are quite inexpensive and work great on my Pagid Oranges! When you change pads, you will need to buy new ones - the stickum is toast and the shims get brittle.
Craig
RS
Here is a pic off my website of them installed:
Old 02-24-2004, 11:11 AM
Craig
RS
Thanks for the advice Craig!
Sprint.
Old 02-24-2004, 04:17 PM
PRO Motorsports
Tyson Schmidt's Avatar
Did you check to make sure the metal brake shield isn't rubbing against the rotor?
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 02-24-2004, 04:39 PM
You mean the metal dust shield? I took them off.
Not to go off topic, but are dust shields important? How many run them and how many go without them? More wind to cool the rotors?
Sprint.
Old 02-24-2004, 07:44 PM
