Limbo
Slider79SC's Avatar
Winter project coming down to the wire
Am I on crack thinking that I can get this all done????
Project list: March 31st deadline…
Engine:
Clean engine parts for reassembly
Clean fan shroud & wiring
Clean headers
Reassemble engine & install
Front End:
Paint cooler panel
Install front bumper
Check passenger turn light bulb
Test fit spoiler & fabricate install brackets
Fabricate cooler brackets
Fabricate brake cooling hose mounts for spoiler
Paint spoiler
Transmission:
Tear down and inspect (5th to 4th downshift)
Replace 5th gear with stock ratio
Install Wevo gate kit
Change shifter springs back to original
Front Suspension:
Remove & inspect bump stops
Replace bump stops if needed & modify
Clean inserts
Clean strut covers
Replace brake line & bleed system
Rear Suspension:
Clean shock covers
Replace & modify bump stops
Replace CV gaskets
Repack CV’s and replace boots (time & $ allowing)
Rear End:
Inspect & replace license lights
Assemble bumper
Final:
Ride height
Corner balance & alignment
Big ol built Duramax
Durango R/T 19’ Current Custom project
V8 M3 08’ Built and spoiled
Old 02-23-2004, 03:31 PM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
Do you have a job?
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 02-23-2004, 03:33 PM
Limbo
Slider79SC's Avatar
Full time 50 hours a week....
I think I am in trouble
Old 02-23-2004, 03:34 PM
LOL, you think?
Second question, are you married?
Good Luck!
'81 911SC Targa 3.6
Old 02-23-2004, 03:36 PM
Limbo
Slider79SC's Avatar
I am married..
Thank god she knows that I am in over my head and tells me to go out and work on it.
I just finished this up last night. (one more coat of paint tonight)
Old 02-23-2004, 03:43 PM
nice doggie
Hetmann's Avatar
We'll if you don't plan on sleeping, you might just make it.
Jerry
78 SC hotrod
02 Mini Cooper S
Old 02-23-2004, 03:44 PM
Nice work, looks like you did it yourself, the stiffening bead is a nice touch.
'81 911SC Targa 3.6
Old 02-23-2004, 03:46 PM
Limbo
Slider79SC's Avatar
Thanks,
I can't take credit for the panel though, that is a TRE piece. I just did the painful part..... cutting my car and welding it in. By the way, the horrible looking welds on the side and where the AC blower used to be is seam sealer, not the welds......
But with two drivers (me & the wife) it needed additional oil cooling ability.
Old 02-23-2004, 03:55 PM
Detached Member
Hugh R's Avatar
Yes
Hugh
Old 02-23-2004, 04:11 PM
MT912RS's Avatar
You could move to Montana, the winters are really long.
Old 02-23-2004, 04:28 PM
19 years and 17k posts...
azasadny's Avatar
Hang in there, you'll get it done!!! Once spring hits, you'll have sufficient motivation!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 02-23-2004, 04:33 PM
Randy Webb's Avatar
Anybody who posts the word deadline in a Porsche thread is on crack.
Old 02-23-2004, 05:21 PM
djmcmath's Avatar
Doesn't Dr. Pate (SCWDP) live in Montana? I'm sure he'd welcome a guest who needed a long winter to finish a project.
As to your deadline, I think it's perfectly reasonable, assuming you mean March 31st of '05. Now, if you could persuade your wife to /work/ on the car, instead of just allowing you to do so ...
Dan
'86 911 (RIP March '05)
'17 Subaru CrossTrek
'99 911 (Adopt an unloved 996 from your local shelter today!)
Old 02-23-2004, 07:21 PM
djmcmath's Avatar
PS -- where /did/ you get that crack, anyway? If you don't mind sharing your source, I'm always on the lookout for the extra-good $h1t.
Old 02-23-2004, 07:22 PM
