xtianw
Guest
Posts: n/a
Engine ID 901 105 111 OR ?
Can some one tell me what car this engine originally came out of?
CM Wagner
1968 911 S Coupe
Light Ivory
Old 01-13-2001, 02:26 PM
Shakenbake
Guest
Posts: n/a
Does your car have the Sportomatic transmission?
Shakenbake (Chris Baker)
1974 911 Coupe
'91 "A" stock champion WV
'90 SCCA FTD
'99 SCCA 3x "A" stock winner
Old 01-13-2001, 03:27 PM
xtianw
Guest
Posts: n/a
no 5 speed
CM Wagner
1968 911 S Coupe
Light Ivory
Old 01-13-2001, 07:59 PM
Early_S_Man
Guest
Posts: n/a
Sorry, Christian, but that casting number won't help a bit! You need the engine serial number and type number from the right crankcase, where they will be stamped on the vertical portion near the fan housing. Your type number SHOULD BE 901/02!!!
Warren Hall
1973 911S Targa
Old 01-13-2001, 08:08 PM
SeriousFunk104's Avatar
Send a message via AIM to SeriousFunk104
If it helps any, my 73 2.4T has the same case number.
Old 02-08-2004, 12:21 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Err Serious, that's a 3 year old thread. But what you say is intruiging.. what induction do you have on your 2.4T? I belive that casting number for an aluminum case while you should have a 3r/4R, 4R/5Rcase or a 7R case
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 02-08-2004, 01:31 PM
LOL, yes it is a 3 year old thread. That’s what I get for running a search and not paying attention. Now for the question that has popped up. L33t9eek my 73T is a "potluck" car. The owner had passed away and the family members had it shipped from CA to MI where I bought it. About all the info I have on the motor is the case number and the serial number of the engine. The S/N checked out in the red book for a 911/91 engine. Where could I cross reference the case number to see what engine it should go with?
Jason
Old 02-25-2004, 05:06 PM
l33t9eek, I am running Webers (40) but the engine was clearly fuel injected from the factory.
Old 02-25-2004, 05:09 PM
Licensed User
Shuie's Avatar
911/91 is a CIS 73.5 911T. I thought those were 7R mag cases.
Where did you find this casting number?
Old 02-25-2004, 05:41 PM
Shuie, I have seen 73E and 73S with 7R cases. But no T. I am guessing the Ts didn't get the better case. Maybe someone can prove me wrong...
Old 02-25-2004, 05:45 PM
