vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Fire Extinguisher Mount
I copied from another thread and mounted my new extinguisher on the tunnel cover between the front seats. This makes for quick and easy access, and the chrome looks cool (let's hope I never have to use it). I was curious how much protection I have with only a one pound chemical extinguisher.
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 05-20-2003, 04:28 PM
Cool
I would get the biggest that you could live with..............Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-20-2003, 04:32 PM
reesestewww's Avatar
Aaaa yea....if you die, it wasn't big enough.
Past:
04 Anniversary 911 #0895, 82 911 SC, 88 Signature Series Carrera, 88 911 Turbo Cab, 73 911T, 63 356B, 06 Cayenne
Old 05-20-2003, 05:50 PM
vesnyder's Avatar
This look prett good ...
Vance
Old 05-20-2003, 06:57 PM
Rick Lee's Avatar
Bump. How is this mounted and where I can I buy such a mount? I need to do this soon.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 02-26-2004, 08:12 AM
Noel's Avatar
I like the location that Vance used. Nice job.
Old 02-26-2004, 08:24 AM
Senior Member
Superman's Avatar
Richard, I like my solution. I bolted a fairly thick plate of aluminum to the passenger side of the tunnel, alongside the console, in the footwell. The extinguisher is bolted to that. Both occupants can reach it easily. The passenger seat has full movement. It's a 5# Halon. I intend to get a dry chemical unit placed in the trunk. The Halon is basically just for an engine fire, in my car. The dry chemical would be for everything else.
BTW, Ron is a fire fighter.
Mocha 1978 911SC. "Coco"
Old 02-26-2004, 08:27 AM
Hilbilly Deluxe
emcon5's Avatar
You don't buy it, you make it.
Details, with another option (mine) here:
My low-budget Fire Ext Bracket
Tom
82 911SC Coupe
GTI Cup #43
Old 02-26-2004, 09:18 AM
na2ub's Avatar
Not to change the topic ... but ... I have been thinking about adding an extinguisher. Question: what type does everyone use. I know our host sells the $$$ type. What is the benefit? Won't a normal dry chemical crush oil / gas fires?
I will sort out a mounting point later. I am leaning to directly in front of the passenger seat, on the floor. I can't mount to the tunnel because I stow the targa top back there.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 02-26-2004, 09:38 AM
HarryD's Avatar
Many threads here and at Rennlist on this topic. Read and make your own determination. You will find where I stand.
Gratuitous picture my my install under the drivers seat:
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 02-26-2004, 09:50 AM
What?
trj911's Avatar
I mounted mine the same place as Harry. Under the drivers seat. I put down some foam and then set the fire extinguisher on it and then cut some foam to go around it so it can't roll. Then a bungee cord to hold it in place and I'm good to go. I also went with the #5 halon sold here. Thanks Wayne!
Tom J.
911SC Cab
SCWDP
CaymanS
Old 02-26-2004, 11:22 AM
I think a "one pound" extinguisher is like a popcorn fart .......sorry, seems too small and may give you a false sense of security. At least without any extinguisher....you realize the risk.
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-27-2004, 09:28 AM
Eric Coffey's Avatar
Originally posted by Superman
...I intend to get a dry chemical unit placed in the trunk. The Halon is basically just for an engine fire, in my car. The dry chemical would be for everything else....
Hmmm, I would think it to be the other way around. You would want the Halon for electrical/cabin fires (just don't suffocate yourself), as it is less effective on exterior (open air) fires. Theory being the Halon starves the fire of oxygen, which is harder to do when there is a plentiful (outside/exterior) source. Not to mention, you would basically destroy the interior of a car with dry chem. Even if you got the fire out fairly quickly, the chem. residue would be nasty. The dry chem. would probably be more effective on an engine fire, yet still messy. The difference is that if you get lucky and extinguish an engine fire quick, you can usually pressure wash the engine bay and get rid of the mess. Having both is probably the way to go, but like you I only have a single 5# Halon (Halotron actually). If I ever had an engine or fuel tank fire, I would take my chances, and try not to lift the deck lid or trunk up very much while unloading the extinguisher!
Old 02-27-2004, 04:58 PM
Cool
all your info is correct, no question; but,
I think what Super means is that his Halon will be his first line of attack at every fire.. sounds good to me.
I'm doing a fume detector as part of a carb install.
Carbs, filters, regulator, and plumbing can be so much fun.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-27-2004, 07:09 PM
Ah, thanks for the clarification Ron. Couldn't agree more. I don't even own a dry chem. Probably not the best idea, but I just tell myself that the Halotron should suffice, and it's better than nothing at all. After seeing the residue left by dry chem, I'll take my chances!
(knocking on all surrounding pieces of wood).
Old 02-27-2004, 11:35 PM
Now in 993 land ...
aigel's Avatar
One pound? You got to be joking. I didn't know that even existed!
If you believe that PCA rules for time trial make sense, you should at least have a 2.5 pound dry or 5 pound halon. I have a 5 pound halon and fastened it to the crossbar of my rollbar.
While it will hold a pound extinguisher, I do not like the idea of fastening 2.5 or even 5 pounds to the trans linkage cover. If you hitt something hard and then roll you have enough things to worry about and don't need a fire extinguisher come loose, beating the living dailight out of you.
That said, I believe the best place to put the extinguisher is on the rollbar, the side of the tunnel or in front of the seat using a bracket.
I had ordered the BK bracket which is VERY NICE. But it works only with a stock seat. So, I recommend you spend a bit more, get a larger bottle and the BK mount, if you still have stock seats.
Cheers, George
81 SC (sold)
Old 02-28-2004, 12:03 AM
Now in 993 land ...
aigel's Avatar
While we are at it: I have read that the dry chem extinguishers can really mess up the magnesium case. Is this correct?
Thanks, George
81 SC (sold)
Old 02-28-2004, 12:14 AM
sounds good to me Eric.
as only a guess,
I'd say that 5# of your halotron would knock down the vast majority of routine car fires.
and for trivia, my battery ground lug is marine style that has the wing nut attachment to the cable for a harried quick disconnect.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-28-2004, 01:18 AM
HarryD's Avatar
as only a guess,
From what I have heard from the guys who refill extingushers, if you can't put the fire out with one unit, usually the use of multiple units does not improve the odds. I carry a 2.5 lb dry unit. I figure I'll make my best effort and then let my insurance take over.
Harry
2020 MB E350 4Matic
Old 02-28-2004, 08:31 AM
Vance. When I looked at that picture I swore it was mine. Right down to the atlas and what looks like winged elm pollen on the carpet behind the drivers seat . what is on top of the folded down rear seats?
The extinguisher doesn't look exctly like mine though.
1979 911 SC Targa
http://www.pelicanparts.com/gallery/Mike_Kast
Old 02-28-2004, 09:07 AM
