LinkBack | Thread Tools |
Rating: ![]() |
Unless the engine is otherwise already subject to detonation(***) there can be NO GAIN from water injection, internal or external.
*** Timing to advanced, octane to low, compression to high...... Last edited by wwest; 07-18-2012 at 06:55 AM.. |
wwest,
Please read the thread. The 'Rubbermaid Solution' uses the latent heat of vaporization in the cooling fan to cool the engine. The water should NOT go in the engine intake. EDIT All through this thread people mis-construe what is happening – ignore those responses. They simply didn’t study the posts. This is all about keeping the cylinders and heads cool, NOT water into the combustion process. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 Last edited by Grady Clay; 07-18-2012 at 07:18 AM.. |
Grady,
I see you are in Colorado, and I can see why you need this to keep the cylinder head cool. I moved from El Paso to Dallas (3500ft elevation difference), and I can see an average of 20F degrees drop in the cylinder head temp measured at the sparkplug. At a higher elevation, there are much less air moving across the cylinder and head. |
Your measured 20ºF drop was only relative to your engine, operating, and ambient conditions. Thus, one cannot make a blanket statement about the validity of a cooling solution based on altitude only. There are more variables than altitude. Sherwood Seine Systems > MPC |
Functionista
Hmm, why not flow a fine mist in front of one of the oil coolers?
Wouldn't this allow for somewhat more even cooling with less water use?
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Spraying at the engine would get the water to the case, cylinder, and head immediately. The air from the engine fan would disperse the water droplets sprayed well. I like Grady's solution. Just as Grady said, this method is not the same as water/methanol injection (into the cylinder). High altitude robs you of power, but also makes your air cooled engine run hotter. Last edited by axl911; 07-18-2012 at 11:39 AM.. |
For a DIY demonstration, with the engine warmed up and idling (high ambient temp day is ideal), squirt some water on your external oil cooler with a spray bottle while observing the oil temp gauge. For real world results, direct a leaf blower toward the cooler w/the water mist to simulate road speed (assume air can turn corners to get to your cooler). Sherwood |
abides.
The heads and cylinders run a lot hotter than either of the oil coolers.
Because heat transfer is a function of the temperature difference, directing the water to cool the heads and cylinders would be a more effective use of the water. If I am not mistaken, one of Porsche's first uses of water cooling was to cool the heads on 962s.
Graham 1984 Carrera Targa |
For street applications, since water storage is finite, water misting is more appropriate for those temp. operating conditions that require borderline cooling, as in full-throttle acceleration, climbing a long grade, pulling stumps or other equiv. conditions. Porsche 962 used water cooled heads, but did so with a closed circulation system. Carrying enough external mist coolant for an endurance event would be iffy, even the time span between fuel stops. If truck racing, by all means ..... If an engine is operating at borderline melt-down conditions, I would go back to the basic build strategy and review some parameters (e.g. excessive boost, compression ratio, max. revs, cooling system capacity, spark lead, etc.). S |
abides.
Yes, I believe that has all been stated already in this thread.
thx Grady for one of your fine example of engineering to address probably the #1 issue when 911 air/oil cooled engines are tracked or pushed hard = the heads & engine get too hot...Thanks again for everything...Bob
I live for 911 tweaks... |
Thread Tools | |
Rate This Thread | |
