1972_911T's Avatar
Cam Cover Restoration
Im looking to restore my cam covers and want to know what the best way to do this is? I have a compressor and paint gun but will I need special heat proof paint or is it best to have them powder coated?
Old 08-06-2005, 02:50 AM
Jim Smolka's Avatar
If they alum, media blasting them looks good. Also powder coating looks good too.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 08-06-2005, 04:44 AM
I just bead blasted mine but they didn't come out as clean and uniform in appearance as I hoped so ended up painting them with several coats of VHT silver which I cured in the kitchen oven. After I was done I found out the neighbor has a polishing set up which he loaned me for some other parts. I don't think polishing would have gotten out all the casting imperfections. Powder coating is a better choice than the do it yourself route after this experience. I had decided on paint since I thought it would be the quickest way to get the parts cleaned up during the rebuild. Turns out I had more time than I thought since the cams ended up getting sent out for a regrind at the last minute.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 08-06-2005, 05:26 AM
Jubbie's Avatar
I used citric paint stripper which worked well. Repainted them with a crackle red paint. They turned out real nice and have held up to the heat.
John F. Lewis
74' 911S Targa + 930/02
76' 914 - Eternal Type IV project FOR SALE
Old 08-06-2005, 08:28 AM
randywebb's Avatar
note the top edges are either sanded or dipped in dark gray -- nice touch.
You can also do different ones in different colors red/black/silver - & change the colors when you change your oil.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 08-06-2005, 03:48 PM
Jubbie's Avatar
Yep, that was a rotery sander to make the sticking out parts shiny. Then sealed it with high temp clear paint.
John F. Lewis
Old 08-06-2005, 04:17 PM
Jubbie, Do you drive that thing? Looks clean enough to eat off of. How do you keep the exhaust pipe looking so good or is it new.
Will program for food
ghnat's Avatar
I had mine powder coated...
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 08-06-2005, 04:26 PM
randywebb's Avatar
now sand the PORSCHE letters with sandpaper on a flat plate
Old 08-06-2005, 06:51 PM
Location: Midlothian Texas about 20 miles south of Dallas.
I used a automotive base/clear paint system but you can achieve the same effect with rattle cans. Good quality high temp paint and sand the raised portions using a sanding block and fine paper.
1981 911SC Sunroof Coupe
2005 Volvo XC-90 2.5T
Vans RV-8 Experimental Aircraft
Old 08-06-2005, 07:53 PM
bead blast and use the Por mfg high end final clear coat. It's good for 400deg.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-06-2005, 08:12 PM
randywebb's Avatar
Anybody have a pic of a cover that's been bead blasted and then left "natural"?
Old 08-07-2005, 12:03 AM
Too bad you didn't ask two weeks ago after I blasted mine. They did not look as good as I would have thought. Lots of asting marks. It also looked like oil had "stained" them. They looked much better painted or powder coated however I wish I had tried to polish them too see what that would have looked like. Someone posted a pic of polished covers a few weeks ago. A search should turn it up.
Old 08-07-2005, 01:42 AM
cjr1's Avatar
Bead Blasted Pics
Here are a few shots of aluminum raw after blasting.If you dont seal them tho,oil & grime will stick pretty easily,ruining the look.
Personally,I'm painting mine,valve covers & cam chain boxes,then hitting raised edges to show aluminum.
Chris
"If you think it's gonna cost $1000, ya better budget for $2000."
Chris
85 Carrera 3.2(Back on the road after rebuild)
02 Trans Am WS6
95 Eagle Talon
98 Bravada(sold)
07 G5
Old 08-07-2005, 08:36 AM
Jubbie's Avatar
Actually I made a dining room table out of the engine
My picture was taken with only a couple of hours on the engine. Looks similar, but not as clean now 1000ish miles later.
John F. Lewis
Old 08-07-2005, 02:50 PM
Early_S_Man's Avatar
Porsche Crest
In '72 the chain and valve covers were Mg ... a rather difficult metal to coat with any durability! Aluminum is a much easier case by comparison!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-08-2005, 01:42 AM
RLJ RLJ is offline
Senior Registered User
Hey Randy Webb,
Are there any heat transfer issues here. Does powder coated or painted covers transfer less heat than raw ones.
Randy Jones
1971 911 "Iris"
Old 08-08-2005, 02:01 AM
randywebb's Avatar
Randy - in a word, No.
(Actually, there will be some very small changes - they could be measured in a lab - or maybe with some good field equipment. But there will be no functional significance to your car from the fact that painted or powder coated covers will transfer a tad more heat by radiation and a tad less by convection than will the metal surface.)
Old 08-08-2005, 01:05 PM
