How to do a carfax on a 1973 911T
Hello ladies and Gents,
I need to do a carfax on a 1973 911T (9113110058). carfax.com needs 17 digits.......help? |
Non Compos Mentis
I doubt they have records back that far. If you do manage to get a carfax, I'm not sure how accurate it will be.
More important is the car's current condition. Look it over carefully, get a pre-purchase inspection, and then decide. |
don't think you can do it.... carfax doesn't go that far back...
dave 1973,5 |
So what would be the best way to get some history and is there a way to match numbers?
Non Compos Mentis
Ask the current owner. They may have reciepts, and may know some history.
I don't have the literature but I think some others here do that has a listing of chassis and engine #'s (I think...)
the vin will tell you something about the car (spec, build date, intended destination for sale etc.) since you provided it someone can post what it "means" engine # will tell you whether it is the "appropriate" motor for the chassis if not whether it's "matching #'s" if you can, try contacting the PO (prev. owner) and see if you can go backwards in ownership I remember going through something similar w/ my T so I know it's not easy
dave 1973,5 |
I wish there was a carfax type database for older cars.
Thanks |
Post the serial # and engine #. We can definitely tell if it's the right engine year, and may be able to tell if it's possibly the original engine.....there's a list for 911S's that may give us clues as to what engine # should be in what chassis #.
You may want to also cross post over to the early S registry...lot's of longhood information on that board. www.early911sregistry.org regards, Eric
http://www.autoforeignservices.com/ 57 Speedster, (4) 67S coupe's, (2) 67S targas, 68L Rally car etc. etc. |
Where is the engine # and serial # located?
Banned
Carfax is only for post 1981 cars.
The engine # is to the bottom right of the fan assembly support - The # reads vertical. The VIN# is stamed on the chassis in the trunk area next to the smugglers box and on the Info plate located in the front trunk area. Good Luck! |
You will need to contact teh DMV in the state it is registered in now. Then trace it back thru other states for each sale.
That's what I did with mine. NOte - privacy concerns apply and they won't tell you the name/address/etc. of each PO. IF you ask they may be able to send a letter you write to the PO's - you can ask for them to contact you, explain what you've done to 'their' car, etc. Enclose a nice pic. Many PO's will be happy to know that 'their' car is still running ...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
