transmission mount slack?
I just put my engine/tranny back in after my first drop. I noticed there is a gap (~10mm) above the rubber on the tranny mounts and the chassis. I can jack the front of the tranny up another 10mm with all the bolts tight. I did some searching and apparently this is normal? Can any experts confirm this?
Also, I would like to replace the transmission mount bolts, but I cannot seam to find them. Anyone have a source?
rhk109 '76 911 3.0 Webers |
bump
large tranny mount bolt pn
901.305.317.00
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Hi rhk109. Yes it's normal. You probably noticed that the bolts were cone shaped on the ends. These tighten and bottom out in the receiving threads in the body.
From what I understand this is normal but my question is why? I changed my transmission mounts a few months ago and noticed the same thing. But why? Why have this space? Why not have it snug? Why?
OK, I am convinced it is normal. Anyone have a good reason why it is designed like this?
My 83SC had the same issue, but maybe only a 5mm gap. It kinda bugged me, so I ground down the length of the metal insert in the rubber mount (not the rubber), and added a few washers under the bolt head. No more gap.
Didn't notice anything unusual after, but it seemed to shift better......
Al Shkuratoff 86 Carrera, SW chip, Fabspeed, M&K 83SC Platinum - Sold 83SC Slate Grey - Sold |
