-   -   correct shade of red for S shroud (http://forums.pelicanparts.com/porsche-911-technical-forum/151126-correct-shade-red-s-shroud.html)
ein 6er 02-29-2004 03:27 PM
is there a rattle can color/brand that is close?
thanks,
doug waters
speeder 02-29-2004 03:42 PM
You will not be able to paint it and make it look "right" since they are color-impregnated fiberglass, but if you must paint it just pick 'normal red' and that will be close enough. :cool:
Zeke 02-29-2004 06:40 PM
They tend to look a little faded as opposed to, say, Guards Red. Mine has given up to be faded plastic pinic tray red. :D
Randy Webb 03-01-2004 09:10 PM
Remove and treat with a fiberglass renewal polish -- rub in well over & over again. You may be surprised.
There was an item in Pano re using a VW red paint that gave an exact color match but as noted above the tone will not be the same.
901/05 03-01-2004 09:52 PM
from the earlysregistry site...
Chuck Miller's thoughts on just that. here
Shawn. SmileWavy
bkrygier 03-02-2004 06:35 AM
I used chevy engine orange
targa911S 03-02-2004 08:10 AM
Chuck would know. I cleaned mine well with mineral spirits, then with laquer thinner. I then hit it with a satin clear. Looks great. All the red paints are not "deep" enough or too deep. Plus it will darken with age and temp wear.
