Project 73 911 R/RS -- Week 2
This was a tough week, but the results were more than worth the effort. And one very important philosophy yielded itself, that is how to ensure you never sell your car. All you need to do is pull the sound deadening tar from the floors. Once you do this job, you will never want to sell your car again.
For a refresher, here's week 1: http://forums.pelicanparts.com/porsche-911-technical-forum/150037-project-73-911-r-rs-week-1-a.html?highlight=r%2Frs I read all the boards on best practices for removing paint and sound deadening. For my 73, a heat gun and heavy duty scraper worked better than a torch. Aircraft coating remover only created a soupy black mess. Heat and scrape and sometimes you could even peal an entire section if you heated ahead of the blade just right. After the floor is scraped, aircraft coating remover cleaned up the areas very nicely. http://forums.pelicanparts.com/uploa...1078100703.jpg Just after initial round of scraping http://forums.pelicanparts.com/uploa...1078100747.jpg After letting a coat of aircraft remover sit for an hour, wire brush and then clean up with paint thinner or mineral spirits. You'll definitely want to wear gloves at this stage. http://forums.pelicanparts.com/uploa...1078100826.jpg After the floors were semi-finished, I started on the body. Here are my new best friends. Note, the aircraft coating remover yielded no fumes of any kind. the spray can paint remover was vicious! It's a wonder I can still type. http://forums.pelicanparts.com/uploa...1078100931.jpg Remover applied. I strongly recommend the plastic sheeting diaper at this stage. Errant scraps of scraped up paint and such are easily contained. http://forums.pelicanparts.com/uploa...1078101039.jpg It took about 3 applications of remover to general and stubborn areas to yield these areas. the spray can was good for trouble spots while scraping/brushing. http://forums.pelicanparts.com/uploa...1078101089.jpg http://forums.pelicanparts.com/uploa...1078101103.jpg http://forums.pelicanparts.com/uploa...1078101157.jpg Next week will be more of the same, but I've got a rhythm down now. Cage stock is set to arrive soon too! |
Good progress for just 1 week!
Did you give any thought to dipping the shell? |
Nice job Shaun!
Hey Chuck,
Yes, but several factors kept me from dipping. First is that the dip gets everywhere and can be hard to get out of the rockers. Other factors that precluded dipping: I would have had to remove the electrical system. This job is already way beyond me, I can't imaging having to pull the system and then get it back in. Also logistically, I have no real access to transport in delivery and pick up. Cost also. I think I'll spend one sixth as much on my strippers and such. This car is really on a budget. Lastly, this is a bonding experience like no other. I intimately know this car now. Can you tell I don't have a girlfriend? :) |
True inspiration! Great job and thanks for posting pics. I am close tostarting the same thing, only I have a wife and two kids to vie for my time as well. Keep us posted!
nice job. i started removing the sound deadening on my car with just a scraper. what a pain!
How many hours would you guess it took to strip the whole car?? I am trying to deside weither to sand off the old paint of us a stripper. I am concerned about strippper getting trapped in the seams, as this can be a huge problem down the road. What would you suggest??
Oh man you're nuts! Wow!!! I definitely took the easy way out and dipped. But I'm pretty impressed by your determination - hope you've been wearing a respirator!
That's just awesome. Keep it up... |
Would some kind of media blasting, especially for the undercoating, yeild good results? I am in the middle of scraping the bottom of my tub. It"s coming off in chunks, from sliding a putty knife under it & prying up. I'm about 30% done & it only took me about 1.5 hours. I've had a couple people suggest dry ice & a ball peen hammer will work good. I should get to try it Tuesday.
very very cool...
Media blasting is unfortunately foiled by tar paper and undercoating - ironically, the undercoating continues to do it's job even as you attempt to kill it with 100psi grit! The media just bounces off. Elbow grease, grinding, Very Nasty Chemicals, or dipping are the only solutions...
Very fast work! :cool:
What colour is it going to be when it's finished? |
I am not too concerned with getting stripper in the seams. I've been washing with mineral spirtis after each strip. Once totally stripped, I will go over with several gallons of acetone. Then perhaps heatgun the seams. Then go overthing with Wurth metal prep, then Wurth Rust Gard. "hope you've been wearing a respirator!" I probably should be wearing a respirator. But then if I did, I'd probably be thinking clearly and give up on this. :) |
http://forums.pelicanparts.com/uploa...1078107386.jpg http://forums.pelicanparts.com/uploa...1078107398.jpg |
if anyone hasn't seen it, you've got to check out his link. |
Shaun,
Great work, be careful with those fumes. Can you borrow a respirator from someone??? Every brain cell counts! |
man you seriously need to get a girl friend, lol great job cant wait to see the finished project, Kevin
I hear you on the bonding experience. There is nothing like dismantling, then reassembling a car to achieve oneness.
I did not dip my '73. But it was truly a case of project creep, I had no intention of stripping down to the shell. It just turned out that way. I was cleaning and stripping as I went, so by the time I made it to the shell there was no point in dipping. My car was covered with aftermarket rust proofing, everywhere: door jams, trunk etc. It took a lot of extra effort to get that crap off. Had I realized how far I would take it, I would have dipped. I did leave the factory undercoating though. Keep up the good work. It is hard and you are obviously putting in a lot of hours. But the results will be well worth it. Driving a car that you built with your own hands is a unique and very cool experience. |
Wow!
| All times are GMT -8. The time now is 05:14 AM. |
