Checking Hub Align / new Rotor
Hello All,
I don't know if this is a dumb question or not but hear goes. I replaced front rotor and wheel bearing races last night. (Used the oven method while the Mrs. was out shopping.) I attached the new rotor to hub and cross tighten the bolts to 17 lb. as per bentley. Is there any way to be sure the hub is centered ? Or should I just grease up the bearings and mount it and spin it to see. Thanks Joe |
Just grease up the bearings and install them. The taper of the bearings will center the hub.
| All times are GMT -8. The time now is 09:05 PM. |
