rfuerst911sc's Avatar
Megasquirt Megatune- any tips on tuning?
I will be receiving in a week or two a EFI setup from Motomotions that includes a Megasquirt II with Megatune. I know the kit will come with instructions and I know the guys there will help via the phone but I thought I would solicit tips from this community. I will be installing TWM 46MM throttle bodies on my stock 83SC with 3.0. The car does have SSI's and a 2 in 2 out MK muffler. Any way I know there are internet forums on Megasquirt but you guys are Porsche specific, so any tips or advice?
Old 12-08-2005, 03:59 PM
I would suggest reading the mega manual as this is my reading for the winter months and have been using the ms for while just don't know how it all works properly..
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 12-08-2005, 04:14 PM
Formerly bb80sc
Vipergrün's Avatar
Getting the car running should be pretty easy by setting some "constant" values and configuring to your particular motor. There are quite a few folks who could send you their config file to get started with. I'll be using a wide-band O2 sensor and the PLX Devices controller connected to the the MS ECU for dynamic tuning. Keep us posted, I am probably a month behind you. I have my Jenvey ITB's setup and ready to install. I'll be using Alpha-N tuning using a TPS. I should have MS pretty well setup for the initial firing Good luck!
-Brad
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 12-08-2005, 07:45 PM
