momo horn button
Hi all,
I'm having trouble with the horn. Can someone tell me how to remove the horn button from the momo prototipio? Actually, maybe someone has experienced this before... The horn works only when the car is turned off or sitting still. Come to think of it, it might be when the car is in gear that it doesn't work, but I haven't tested that theory. Anyone ever dealt with sonething like this? Thanks
John |
Are you using a hub spacer?
If so, the connection between the wheel and hub is not good enough. Let me know and I'll go through it with you.
George M '89 Carrera 3.2 '91 928GT '76 914 '18 Macan GTS |
hmm, i just got the car. sorry, i'm kind of a newbie... how do i tell if it has a spacer?
John |
The horn button is only held on by friction. Just pry the horn button up and it will come out.
If you have a spacer, it will be in between the wheel and the hub.
