Door/window maintainence?
Hi Folks -
My door panels are coming off for some upholstery work. Any suggestions on what to service? I have power windows, door locks, etc. Thanks, Seth |
clean the holes
check for rust repl. stereo speakers & wires grease on window gears check vibration damper on that rod gizmo in there think about renewing or adding to the sound deadener -- use a light wt. product if adding material grease the door hinge if not done recently install rubber plugs for noise reduction |
| All times are GMT -8. The time now is 03:11 AM. |
