I need to replace rubber hose oil line ( this one with metal fiting)
Oil tank -engine Question :Should I replace heat exchanger on driver side or could I do it without dismantling heat exchanger? Tomy |
Friend of Warren
I don't know how you could possibly get in there to get a wrench on the fitting with the exchanger in place.
Kurt V No more Porsches, but a revolving number of motorcycles. |
If it the hose that connects to the driver side of the case, you will need to R&R the driver side heat exchanger. No way around it.
Chuck Moreland - elephantracing.com - vonnen.com |
