kanihitit's Avatar
Long Stroke 3.4?
Hello Pelicanites,
I have a quick question: Does a 3.0 case with a 964 crank, the appropriately machined rods and 98mm pistons make a long stroke 3.4?
Old 03-02-2004, 11:18 AM
Licensed User
Shuie's Avatar
I dont think you can use a 964 crank. rdane is building a 3.4 from a SC motor with a crank from a 3.2 Carrera and a set of 98mm P&Cs. Check it out over in the engine rebuild forum.
Actual compression with 3.4 max moritz?
Your guess on HP #s?
Old 03-02-2004, 12:58 PM
