Eugene at Pelican Parts's Avatar
Pelican Parts New Products from Pelican!
Hey guys,
I've got another update for you... 101% gimmick free!
Need to shed some pounds off your tail? If that protein diet isn't working, then give these 911R taillight kits a try! Guaranteed to make your rear shine!
Bored? I didn't think so... but you can be now! With our new selection of JE Pistons and Perfect Bore Barrels, you can get a little more bore in your life by upgrading to oversized pistons and cylinders for your 911. Make that rebuild worthwhile by kicking it up a notch. Why not? It's your precious! Available in a variety of sizes, even your late model 911!
Want stronger rods? I knew it. Now you can replace your old ones with a set of forged Carrillo H-Beams. Never worry about your rods again!
eugene@pelicanparts.com
Eugene (Formerly) at Pelican Parts
Pelican's E-Commerce Guy, 2003-2011
2001 330i Sport
1983 911SC Coupe (sold)
Old 02-17-2004, 09:41 AM
Friend of Warren
Eugene, keep your day job. You'll never make it as a comedy writer!
Kurt V
Old 02-17-2004, 11:30 AM
I was thinking Radio Anouncer!
Eugene, tough crowd Huh!
I'll take a look at the new stuff anyway!
Bill Miller
81 Targa Guards Red
3.6, M&K 1 out, S4 brakes
83 ROW CAB Rubinrot Metallic (RIP)
Old 02-17-2004, 11:58 AM
It's much funnier if read with an Austrian accent (no offense).
Try it! NOW!
2001 330i Sport
Old 02-17-2004, 12:16 PM
Not bad and I'd like an "Onion" with that!
I looked at the P&C's
JE I assume has a site.
Can we find more details on the Cylinders somewhere?
Bill Miller
81 Targa Guards Red
Old 02-17-2004, 12:37 PM
http://www.perfectbore.com/motorsport1.htm
Additionally, I will be expanding the cylinder lineup to include LN Engineering's "Nickies" too. More to come.
2001 330i Sport
Old 02-17-2004, 01:01 PM
Randy Webb's Avatar
How much does the AR-911R-RKT2 with the backup lights weigh??
Old 02-17-2004, 03:04 PM
Roughly 1.5 lbs for the pair. Anybody wish to post how much the stock light assemblies weigh?
2001 330i Sport
Old 02-17-2004, 03:39 PM
Fabricator
Stock Lamps weigh over 9lbs
Old 02-17-2004, 04:48 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Piston & Cylinder Set (95mm bore, 10.3:1 comp), 911 Euro 3.2 (1984-89)
99-0174-915 $2500.00
JE Pistons, set of 6, 3.2l, 95mm bore, 10.5:1 comp, 911 (1984-89)
JE-212440 $725.00
Perfect Bore Barrel Cylinders, set of 6, 95mm bore, sealing ring groove, 911 (1978-89)
PB-BL95-103SR $2,000.00
$2500 For MahleForged or $2750 for Aftermaket Pistons Not Forged and Barrels from Who.Never heard of them, did a Google search, Nada Could not find anyone using there Cylinder in racing or anything .Did find out they made parts for Airbus. Thats scary, if its not a Boeing Im not going.? Steve
Old 02-17-2004, 05:50 PM
First, visit these links:
link 1
link 2
link 3
Then, Google
Apticote Ceramic 2000
And then realize you're Boeing smoke up the wrong hole (Austrian accent).
hehe
2001 330i Sport
Old 02-17-2004, 06:35 PM
Alan Cottrill's Avatar
any plans for 90mm pistons?
big AL
'77 911
Old 02-17-2004, 06:39 PM
For any unlisted applications, email me with details about your setup. I will most likely be able to get what you need. JE doesn't have part numbers for everything, but that doesn't mean we can't supply them to you.
2001 330i Sport
Old 02-17-2004, 07:08 PM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
I'm curious, why aren't there any JE piston sets for force induced engines that need lower compression in the 7-8:1 range?
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 02-18-2004, 07:50 AM
JE Pistons does not stock every piston in the world, but that doesn't mean they don't supply them. Less popular applications are available by special order, so please contact me for anything not listed. Special orders take 3-4 weeks, so please schedule your build accordingly.
From the description in our catalog, "these pistons are machined from forged 2618 alloy."
Hope that clarifies things.
2001 330i Sport
Old 02-18-2004, 11:38 AM
DG624's Avatar
Are the pistons and connecting rods lighter than stock? What is the stock compression? DO you also have dual plug heads? What would be the power gain and how about longevity?
Old 02-18-2004, 12:41 PM
1fastredsc's Avatar
They are much lighter, we used JE pistons and Pauter rods in my dad's 944 turbo and the difference in weight for the pistons alone was like night and day, even more appearant with the rods attatched to them.
2007 Mazda 3 hatch
Old 02-18-2004, 12:52 PM
DG624's Avatar
I have an '86 Carrera with 3.2. I am thinking about replacing the valve guides (600 miles a quart on oil) and think that this may be worth the extra money if I am going into the engine.
My question is why didn't the factory use the light weight parts and would the lighter parts last as long?
Old 02-18-2004, 01:05 PM
According to my specs, JE Pistons are roughly 200g lighter than stock (each) and Carrillo rods about 50g lighter (each).
Stock compression for an 86 3.2 is 9.5:1 USA or 10.3:1 ROW. JE Pistons are available in 9.5:1 or 10.5:1.
You can have your stock heads machined to accept dual plugs, but then you will need a dual distributor to match.
Mahle and JE Pistons are very reputable manufacturers of engine components that have both been around for over half a century. I would put JE's in my car and expect them to be just as reliable as the ones they've replaced. That's just my opinion though, so ask around to see what the consensus is.
2001 330i Sport
Old 02-18-2004, 03:39 PM
DG624's Avatar
I was thinking that a higher reving lightweight engine would be more powerful and less trouble. Maybe the twin plug head is not worth it since the Motronic does not have a knock sensor. This seems to get into more than I was intending...change the pistons and rods for more free reving power...must change the ignition to change to twin plugs. Can I go to 10.5:1 with 94-94 RON or should I stay at 10:1? Should i also replace the rod bolts for a car that will not go over 250 HP?
Old 02-18-2004, 03:54 PM
