-   -   Heat exchanger removing (http://forums.pelicanparts.com/porsche-911-technical-forum/151576-heat-exchanger-removing.html)
Tomy 03-03-2004 06:57 AM
Hi,
I have read a lot about horrible heat exchanger removal procedure. As I have oil line to exchange I found that I need to remove HEX. I have waiting till now to do it (4 weeks) as I dont need to have ready car before april. (winter here)
Ok. Whats hapen - I take off HEX in 10 minuts!, no problem at all.
I even not use any heater to make studs RED. I am so happy.
From second side I need to replace oil line (I have new one alerady), but I am not 100 % sure that my oil problem is coming from this point- everythin is looking like this but...
Any other idea from where oil (a lot of oil) could get out from driver side of the engine. (When I start engine it blow out oil someware in this place when oil line is coming to engine.
regards
CHILI 03-03-2004 08:48 AM
Any pictures? Are you referring to the oil return tubes?
Tomy 03-03-2004 09:51 AM
not oil return tube
no, no I need to replace (I hope ) oil line coming from oil tank to engine.
CHILI 03-03-2004 11:52 AM
Ok, I think you are speaking about the line that's got a 36mm nut and a 32mm insert that goes into the case at the front of the motor and the line runs under the bellhousing?
