kfosburg's Avatar
Send a message via AIM to kfosburg Send a message via Yahoo to kfosburg
Leaky Fuel Pump... options?
Hi,
I have a 71 911E, converted to Webers many years ago w/original Bosch fuel pump. After sitting around for a few years, I've started restoring it and found the fuel pump leaking quite a bit where the electrical connector mates the body. If I somehow uncrimp the body housing to take it apart, is there a gasket that can be replaced, or should I just purchase a rebuilt one and be done with it? The pump works fine otherwise.
Thanks,
Karl
Old 03-02-2004, 01:40 PM
ruf-porsche's Avatar
Purchase a new fuel pump, don't want an engine fire to destroy your car for a 25 buck fuel pump.
Old 03-02-2004, 03:26 PM
there are several quiet inline pumps that put out about 3# pressure that are cheap and easy to install. about $65 for the one i usually get.
206 637 4071
Old 03-02-2004, 03:31 PM
kfosburg's Avatar
Thanks for your suggestion. What would you recommend for a substitute for the original Bosch? Also, should I relocate it to the engine compartment instead of the under the chassis location it is now?
Thanks,
Karl
Old 03-03-2004, 02:03 PM
