brawlins's Avatar
Sunroof
One of my sunroof seals (you know - those black strips that help keep the water and air out) on my 82SC is starting to come off on one side.
What type of glue do you use to glue those suckers on?
Any suggestions will be greatly appreciated.
- Bill
1982 Porsche 911SC Coupe
1999 Porsche 911/996 Coupe
Old 03-06-2004, 07:49 PM
3M black weatherstrip adhesive.
206 637 4071
Old 03-06-2004, 07:51 PM
brawlins's Avatar
Mucho thanks for the quick reply! I assume I can get this at my local Parts store?
Old 03-06-2004, 07:53 PM
pjv911's Avatar
Send a message via AIM to pjv911
Yep. Be sure to buy it in the sqeeze tube. Not the spray can.
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 03-06-2004, 08:09 PM
fred cook's Avatar
Cool Weather strip glue.....
If you have a local NAPA parts store, they should carry both the black and yellow trim cement.
Fred Cook
'80 911SC coupe
Old 03-06-2004, 08:51 PM
I've done it twice with the spray can adhesive. For the front portion, you can do it with the sunroof in. Spray the adhesive in a jar and then paint the metal portion. Mask off the felt that your adhering just at the edge you want the glue not to show and then spray. Apply it like you would any quick bond rubber cement. The rear requires the removal of the sunroof but it is similar.
Old 03-06-2004, 09:29 PM
