response to longboard- Kryloned
On the fan-Just clear krylon spray paint. A hack way to do it but I figured it will be simple to strip off.
I've never heard of Zoops. I heard of some stuff called Glisten from Por 15 thats a clear protective coating. I can tell you that Por 15 is great but after you open the can it has a short shelf life. My car is metallic silver so I painted my engine bay with their silver Por 15. I came out Ok but the color is brighter and more foil like. I rolled it on after cutting in to the tight spots. I had sprayed a 914 bay with it and vowed never to spray it again. I even used charcoal respirators and a smock. Prep was everything. It'll tame down in a few months. I like it because you can spill anything on it and it won't melt. It will fog and discolor under UV but not if you top coat it. It's lauded all over the web. You can see the original color of the bay by the hinge on the hood. Tarnished silver. Last one was a joke.
