Kill Switch for 86 Carrera
Thanks to pelican parts, my dad has an 86 Carrera Cab on the way from Virginia. I found the car in the classifieds here, and got some great PPI advice. Other than a couple niggly little issues, the car checked out great.
There is no way the car would have been bought without this great resource. Thanks! Anyhow, dad's insurance says we need an anti-theft device installed. I hate the idea of some crap-tastic aftermarket alarm, and thought a simple hidden kill switch would be the ticket. What should we wire it to? fuel pump? DME?
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats |
Sultan of Sawzall
For a quick & easy solution that will probably satisfy that need, how about one of the "screw-type" battery disconnects? They're usually under $10.
Gruppe B #319 2 '86 911 Carrera coupes (red & white) '66 Corsa convertible 140/4(red) '66 Monza coupe 110/PG(white) '95 993 cabriolet (wife's) |
That would be quick & easy, but I don't know if that would be sufficient for the insurance co. Plus, I can guarantee that neither dad or his wife will want to pop the hood to dsconnect the battery when they're downtown.
are you sure it doesn't have the factory alarm installed?
-Matt 1985 Targa |
I've installed a kill switch in my fuel pump circuit in my SC, just hijack the wires going into a fuse box and run some wires into the passenger compartment to a clever spot where you can mount a switch. With the fuel pump circuit disconnected the car will turn over but won't fire so I imagine any thief trying to hot wire it would either burn out the starter or kill the battery.
Noah 79 SC minerva blue metallic Eureka CA / Boulder CO Physics is like sex, yes there are some practical applications, but that's not why we do it. |
One of the tricks some people use is to buy a factory switch for an option the car doesn't have and install it in the dash in the factory location. Something like a headlight washer switch, or some such. Then you can run wiring from the switch to accomodate whatever anti-theft measure you want. Convenient to use and the average thief is unlikely to notice it, as it doesn't look like something added later and an attempt at hiding something.
Chuck Stoddard once gave a description of a simple anti-theft wiring modification for the 911SC-era cars. It was originally posted in Pano and then re-printed in the Up-Fixen series of books. If my memory is any good, the neat thing was it would allow the car to start, then die. The theory was the thief would assume there was something wrong with the car and go elsewhere. I don't recall the details but perhaps you could look it up and get a few ideas. Perhaps it could be adapted to a later car. JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle |
Great info, thanks folks.
I especially like the idea of "hijaking" a line from the fuse panel, and using a factory switch.
http://www.canadiantire.ca/browse/product_detail.jsp?PRODUCT%3C%3Eprd_id=84552444329 4641&FOLDER%3C%3Efolder_id=1408474396672395&bmUID=1171059093362
Dan 88 930 blk/gry |
So I'm headed up to Montreal in two weeks to get dad's car "prepped" for the season... oil change, fiddle with the heater controls and a few other small items.
Top of the list is installing a kill switch; he can't get theft insurance until one is installed. On an 86 Carrera, which circuit is best to interupt? I could run the switch to a ground, but what component should be disabled by the switch? I'm thinking just the coil, would that be easiest?
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats Last edited by notfarnow; 03-23-2007 at 05:55 AM.. |
The ground wire that runs off of the DME main/fuel pump relay under the drivers seat next to the ECM is a good interruption point. IIRC, it is a brown wire off of terminal 85.
The wire (along with others) runs from the relay, over to the drivers side, and then back toward the engine bay. When engaged, the car will crank but not start. Where you run the wiring and put the switch is up to you. If you want more info or wiring diagrams shoot me an email.
-Matt 1985 Targa |
Slumlord
A battery kill switch will lose all your radio pre-sets. Kill the ignition system or the fuel pump with a switch inside the car. Or add the old style high beam switch on the floor.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Glad I could help...my only advice would be to take your time soldering the switch and connections, as this is obviously something that could strand you somewhere down the road. Good Luck!
-Matt 1985 Targa |
Another great tip... left to my own devices I probably would have used crimp connections.
Thanks!
The Unsettler
PO may not have known about factory alarm.
Open drivers door, is there a small lock cylinder in the door? Scott
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Just use connectors that are better than the crap that is sold in the auto parts stores and use a good quality crimper, designed for the specific connector you plan to use. JR |
Slumlord
If crimped connectors didn't work, then most cars would ever start.
If you look at the wiring diagram, there are a 12V leads from the ignition switch which turns on:
1. the ignition OR 2. the starter relay If you intercept either one and put a simple, low current switch in line that is hidden under the dash, you don't have to change the factory wiring and should prevent your car from starting. I'm thinking the yellow wire for the starter relay would be good. It would seem as if the battery is too dead to crank. Find some nice crimp connectors and use shrink wrap tubing to make things clean. The important part about using crimp connectors is the right crimping tool. Search the internet a bit and you'll find a nice tool, which forms a factory-style crimp. This website has the wiring diagrams for the entire car and ignition switch. Doug
1971 RSR - interpretation |
Thanks.
Fat butt 911, 1987 |
