mating 915 to 3.2L
I have a 3.2L engine from a 1986 (did those use the G50's?) and a 915 that I think is the original one in my 1973 911. What do I need to do to mate them together?
Do I use the stock 3.2L flywheel? What clutch items do I need? Thanks! |
the '86 3.2 was still mated to the 915 trans. I have the same combo in my car. ('86 engine, '73 trans) I am not sure on the flywheel and clutch stuff. I do know you have to notch the bell housing for some of the DME sensors.
Keeper of the Titanium Monkey 1975 911S (sold) 1973 911 w/3.2 (sold) 1983 911SC targa (sold) Looking for a 987.2 or 981 Cayman |
The stock flywheel should work as that 3.2 was originally mated to a 915. Same with a clutch. '84-'86 clutch parts mated with my '76 915 just fine.
You need to notch the transmission to allow for the speed and reference sensor (the notch at about 2:00 as viewed from the transmission end of the engine). The notch at top dead center is not required as that sensor doesn't do anything... Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
Yeah, I think it is just a diagnostic tool - it serves no purpose in actually making the engine run...
Mike
Thanks - I don't need any sensors as i have carbs on. But I don't have the 3.2L clutch stuff, only the 3.2L flywheel.
I do have the original clutch stuff from where the 915 was mated to a 2.&L the PO had in the car. Would any of that work? And if I replace the disc, what p/n should I get? Or what size is it, etc. |
If you are not using the DME & sensor for ignition timing, what distributor are you using with the carb conversion? The 3.2 distributor does not have any provision for timing advance because the DME does that, right? I believe my conversion used a Euro 3.0SC distributor because it has mechanical advance. TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
