Randy Webb's Avatar
mating 915 to 3.2L
I have a 3.2L engine from a 1986 (did those use the G50's?) and a 915 that I think is the original one in my 1973 911. What do I need to do to mate them together?
Do I use the stock 3.2L flywheel?
What clutch items do I need?
Thanks!
Old 03-04-2004, 09:41 AM
thrown_hammer's Avatar
the '86 3.2 was still mated to the 915 trans. I have the same combo in my car. ('86 engine, '73 trans) I am not sure on the flywheel and clutch stuff. I do know you have to notch the bell housing for some of the DME sensors.
Keeper of the Titanium Monkey
1975 911S (sold)
1973 911 w/3.2 (sold)
1983 911SC targa (sold)
Looking for a 987.2 or 981 Cayman
Old 03-04-2004, 10:02 AM
IROC's Avatar
The stock flywheel should work as that 3.2 was originally mated to a 915. Same with a clutch. '84-'86 clutch parts mated with my '76 915 just fine.
You need to notch the transmission to allow for the speed and reference sensor (the notch at about 2:00 as viewed from the transmission end of the engine). The notch at top dead center is not required as that sensor doesn't do anything...
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 03-04-2004, 11:04 AM
Friend of Warren
Mike
Which brings up a good observation. The top sensor is the TDC sensor, which during my rebuild I bought a new one. I then discovered that the other end of the wire just goes to a capped off plug under the intake manifold. It serves no purpose. Is this just used for some piece of test equipment?
Kurt V
Old 03-04-2004, 11:12 AM
IROC's Avatar
Yeah, I think it is just a diagnostic tool - it serves no purpose in actually making the engine run...
Mike
Mike
1976 Euro 911
Old 03-04-2004, 11:43 AM
Randy Webb's Avatar
Thanks - I don't need any sensors as i have carbs on. But I don't have the 3.2L clutch stuff, only the 3.2L flywheel.
I do have the original clutch stuff from where the 915 was mated to a 2.&L the PO had in the car. Would any of that work?
And if I replace the disc, what p/n should I get? Or what size is it, etc.
Old 03-04-2004, 11:47 AM
ttweed's Avatar
Randy-
If you are not using the DME & sensor for ignition timing, what distributor are you using with the carb conversion? The 3.2 distributor does not have any provision for timing advance because the DME does that, right? I believe my conversion used a Euro 3.0SC distributor because it has mechanical advance.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 03-05-2004, 08:16 AM
