-   -   Compression Testing a 2.7 with Carbs (http://forums.pelicanparts.com/porsche-911-technical-forum/151946-compression-testing-2-7-carbs.html)
techguy 03-05-2004 12:33 PM
Hey Guys,
Bought a nice compression tester last fall and with the weather warming up this weekend I figured I would try it out on the car. Obviously I am going to disable the fuel pump but have questions on the engine prep before the test.
My thoughts are to run the test with a cold motor and all plugs in. Is this correct? I figure with the plugs in the back pressure would be more like actual operating conditions?? I have also read that the plugs should be removed cold due to expansion and possible damage to threads on a warm engine???
What procedures are correct?
A Quiet Boom 03-05-2004 01:26 PM
I've always done compression tests with all the plugs removed for two reasons. First the tester screws into the spark plug hole so removing them makes sense and second the starter can spin the engine more easily with them removed so the readings are usually more accurate.
A Quiet Boom 03-05-2004 01:27 PM
Oops, one more thing. Yes it is better to remove the plugs cold on ANY aluminum cyl. head.
RoninLB 03-05-2004 02:25 PM
I like to unplug the CD,
keep throttle WOT
911pcars 03-05-2004 03:30 PM
Warm engine to operating temperature
Remove all plugs
Ground the coil wire (remove from distributor cap)
Open throttle
Crank engine for 4 compression strokes (go 8 if you have an early S or with agressive cams); record the last reading
Sherwood
techguy 07-30-2005 09:16 PM
This is tomorrows job finally.
The big question, hot or cold when running test? Plugs in or out?
john walker's workshop 07-30-2005 09:49 PM
normal operating temp, plugs out, crank each cylinder about 10 pumps or until the gauge stops moving.
techguy 07-31-2005 08:51 AM
Should I back the plugs out a bit prior to running the motor up so the removal is easier and I do not damage the threads?
