Fan In The Whale Tail?
Has anyone installed a Spal or other type fan in the whale tail in order to cool the A/C condensor? Picts and details please.
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint Last edited by brcorp; 03-07-2004 at 05:54 AM.. |
Would also be interested to know if anyone has installed one to cool an intercooler.
"Igneous Aquam et Laudi semper" Carl Muckley |
Bill: I haven't done it, but I think it's a worthwhile upgrade. Install the biggest fan possible. Wire it using a relay off the trigger wire for the compressor, with power coming from another source.
Hugh R wired in a couple of computer cooling fans on his non-turbo car. He says they help a lot when he's in slow moving traffic. Here's the thread: Computer Condenser Fans Scott
1984 Targa Last edited by scottb; 03-07-2004 at 07:36 AM.. |
I've seen this done for transmission coolers on drag cars, it allows the racer to keep the tranny cool when staging etc. I personally used one as "air conditioning" inside my drag car, I just made a bracket and used a sheet metal screw to hold it near the rearview mirror aimed at my helmut. They are great little fans but based on my computer experience don't like dust very much. Try to get ball bearing fans as opposed to the bushing type fans which wear out faster. Sunon is a good brand.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com 1966 912 converted to 3.0 and IROC body SOLD unfortunately ![]() 1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity! |
Unregistered
Seems to me that if you sealed the area between the condensor and deck lid and sealed around the decklid to body seam all the air from the engine fan would have to go through the condensor, right? Even at idle those things move a pretty good chunk of air.
It might make the engine run a little hotter tho....... |
